Home > Maintenance & Mods (L322) > Rear washer mod |
GJOB Member Since: 24 Oct 2010 Location: Northants Posts: 131 |
Brilliant, thanks! |
17th Dec 2013 8:32am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6737 |
When I was taking pics for the write up, these were the just small screws I had lying around that happened to fit, but I don't think they have to be exactly the length in the pic. Got - 2017 SDV8 Autobiography in Loire Blue
17th Dec 2013 9:41am |
I see, thanks for the reply. I'll keep googling or pop down to the local hardware shop. |
17th Dec 2013 10:44pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
I too used screws that where lying about, but did'nt have any that small, so used slightly longer ones, they poke through the plastic bit by 2-3 mm. If it dont work.......burn it!
18th Dec 2013 12:21am |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
20 minutes to do the whole job...Great explanation given and pretty easy to do....Tested, tested and tested again and spot on..fingers crossed it does the job for a long while. The power of the forum yet again saves me a ton of cash!. |
11th Jan 2014 1:55pm |
11th Jan 2014 8:11pm |
will do..cheers! |
11th Jan 2014 8:20pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
replaced the rear washer seal in the wiper motor today( found water in my amp)
17th Jan 2014 6:15pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
My rear washer water comes out on to the screen and does not leak in the car, however, the water comes from around the base of the wiper arm on to the screen. I have tried to poke a pin in the washer jets but no difference although they appear unblocked.
12th Mar 2014 2:14pm |
