Home > Maintenance & Mods (L322) > Rear washer mod
GJOB
2005 Range Rover Vogue SE Td6 Java Black
Brilliant, thanks!
Post #229727 17th Dec 2013 8:32am
GJOB
What about the type of screws - 5mm Self Tapping, Galvanised? All the results seem to show screws that are too long.
Sorry for the spoon feeding questions :/
Thanks
GJOB
Post #229728 17th Dec 2013 8:35am
When I was taking pics for the write up, these were the just small screws I had lying around that happened to fit, but I don't think they have to be exactly the length in the pic. Got - 2017 SDV8 Autobiography in Loire Blue
Post #229735 17th Dec 2013 9:41am
GJOB
I see, thanks for the reply. I'll keep googling or pop down to the local hardware shop.
Post #229916 17th Dec 2013 10:44pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
I too used screws that where lying about, but did'nt have any that small, so used slightly longer ones, they poke through the plastic bit by 2-3 mm. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #229948 18th Dec 2013 12:21am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Washer Mod...just done it.
20 minutes to do the whole job...Great explanation given and pretty easy to do....Tested, tested and tested again and spot on..fingers crossed it does the job for a long while. The power of the forum yet again saves me a ton of cash!.
Post #234092 11th Jan 2014 1:55pm
Welshdragon
Just keep an eye on it when you use the screen wash, I left the tail gate cover off for a few days while using the rear wiper washer, just encase it leaked.....again! If it dont work.......burn it!
Post #234142 11th Jan 2014 8:11pm
paulmoran2
will do..cheers!
Post #234145 11th Jan 2014 8:20pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
replaced the rear washer seal in the wiper motor today( found water in my amp)
30 mins and £1.60 for the new seal. cheep at twice the price,
http://www.fullfatrr.com/forum/topic9924.html
spot on, cheers for sharing
nige
Post #235574 17th Jan 2014 6:15pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
My rear washer water comes out on to the screen and does not leak in the car, however, the water comes from around the base of the wiper arm on to the screen. I have tried to poke a pin in the washer jets but no difference although they appear unblocked.
Is this the fix I need to try or do I have a different problem? Any idea where to get the washer as the item in the link is no longer active. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #247771 12th Mar 2014 2:14pm
