Home > Technical (L322) > Unacceptable battery drain |
billcyn Member Since: 20 Oct 2013 Location: Whitby Posts: 56 |
Hi
11th Nov 2013 4:50pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
A faulty FSR draining current whilst the car was asleep could well be your problem. Even with a current drain they can work perfectly and show no signs of failure. Unfortunately they don't seem to be testable for faults.
11th Nov 2013 5:23pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
And make sure the ODB port in the drives footwell is closed - this was the source of one battery drain issue on here! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
11th Nov 2013 7:21pm |
Thanks for all your suggestions. Will be checking the alternator tomorrow and ordering a replacement FSR if no fault found. Any idea where I can source a genuine FSR?
11th Nov 2013 7:26pm |
FSR from Dan@Duckworths..... site sponsor.
11th Nov 2013 8:05pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
I too had a dead battery after a number of "leave the boot open" moments !
11th Nov 2013 10:25pm |
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 |
Definitely change FSR before doing anything else. Like you, I replaced the battery first with a recommended one from a battery specialist, but it made no difference and I believe to this day it was a brand (Alphaline) and it just wasn't up to the job. Your choice of Bosch was the right one.
12th Nov 2013 7:54am |
Update - further checks done today.
12th Nov 2013 3:09pm |
Removing the heavy cable between the alternator and the starter solenoid isolates the alternator.
12th Nov 2013 4:16pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Alternator! |
12th Nov 2013 9:20pm |
Hi Wealy
12th Nov 2013 10:24pm |
Yep
12th Nov 2013 10:39pm |
Oh
12th Nov 2013 10:41pm |
Thanks for that. If new FSR doesn't fix it then it will probably be a replacement alternator (under warranty all being well) |
12th Nov 2013 10:53pm |
