Home > General > Problems !! still |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
Has anyone had gearbox problems shaking or a stutter around 1500 revs its done 99 thousand miles would changing the fluids make a diff ?? if this is a fault of the box |
18th May 2010 9:56am |
Considering the fluid life on the gearbox is 60,000 miles, less on the GM you should probably do that anyway. Then see if it improves. Often people say it improves shifting but I cant say I noticed a difference when I did mine @ 110,000 Miles! |
18th May 2010 11:14am |
yes it seems to be when i hold the throttle steady around 1500 to 1900 rpm |
18th May 2010 5:00pm |
Stuttering & juddering are often coil pack related. Are you sure its from the Trans? Have you checked the PCV hoses for leaks (if you're BMW) the spark plug wells can fill up with oil which messes with the coil pack to plug connection.
18th May 2010 5:10pm |
Mine is a TD6 |
18th May 2010 6:50pm |
how do i find out how much oil and spec for my box |
18th May 2010 7:18pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
There is some info here:
18th May 2010 7:40pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 765 |
Also have the injectors checked. |
19th May 2010 5:31am |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi probaley not what you want to here,but it sounds like what i had and would be a light shudder around the 25 to 30 mph on light throttle, if you give more throttle from standstill it seems to not happen... it was the toque converter shuddering,trying to lock internally V8 facelift Range Rover Autobiography 22" wheels.
19th May 2010 7:21am |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Torque converter is what I was going to suggest as well.
19th May 2010 10:29am |
Well im home and RR on a recovery truck lost all drive and I can hear a noise coming from the front in the bell housing. so is it the converter I need to change or the box too ?? I also had TRANS.FAILSAFE.PROG on the dash so guys any ideas . |
19th May 2010 6:23pm |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 863 |
Sorry to hear that mate. Hope the bill isn't too painful..... Trans failsafe is just the car saying that its detected a gearbox/ drive fault of some sort, and gone into limp mode.
19th May 2010 8:01pm |
well its official torque converter and box wrecked!!! and only 30 miles from when it 1st felt odd so if you have a TD6 and its done 50,000 miles change your transmisssion filter and fluid NOW dont wait 30 miles like i have !! take it from me 50.000 miles then 100,000 and onwards for a cost of around £120 to 250 get it done instead of £1000s like i have !! |
23rd May 2010 11:59pm |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 |
I have had a 5 gearboxes in my TD6. Land Rover charge thousands.....
24th May 2010 6:56am |
