Home > General > Problems !! still
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
Problems !! still
Has anyone had gearbox problems shaking or a stutter around 1500 revs its done 99 thousand miles would changing the fluids make a diff ?? if this is a fault of the box
Post #18411 18th May 2010 9:56am
dan_uk_1984
Considering the fluid life on the gearbox is 60,000 miles, less on the GM you should probably do that anyway. Then see if it improves. Often people say it improves shifting but I cant say I noticed a difference when I did mine @ 110,000 Miles!
Post #18418 18th May 2010 11:14am
daveo
is the shuddering more noticeable if you throttle lightly oppose to putting your foot down.
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #18431 18th May 2010 3:53pm
simonmanx
yes it seems to be when i hold the throttle steady around 1500 to 1900 rpm
Post #18435 18th May 2010 5:00pm
dan_uk_1984
Stuttering & juddering are often coil pack related. Are you sure its from the Trans? Have you checked the PCV hoses for leaks (if you're BMW) the spark plug wells can fill up with oil which messes with the coil pack to plug connection.
Dan
Post #18436 18th May 2010 5:10pm
simonmanx
Mine is a TD6 Thumbs Up
Post #18441 18th May 2010 6:50pm
simonmanx
how do i find out how much oil and spec for my box
Post #18445 18th May 2010 7:18pm
Fox
There is some info here:
http://www.fullfatrr.com/forum/topic1259.html
Not a specific amount of oil, but less than 7 litres.
Post #18448 18th May 2010 7:40pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Also have the injectors checked.
Post #18456 19th May 2010 5:31am
daveo
hi probaley not what you want to here,but it sounds like what i had and would be a light shudder around the 25 to 30 mph on light throttle, if you give more throttle from standstill it seems to not happen... it was the toque converter shuddering,trying to lock internally V8 facelift Range Rover Autobiography 22" wheels.
Post #18458 19th May 2010 7:21am
SteveMFr
Site Sponsor
Torque converter is what I was going to suggest as well.
The issue is wear in the valve bores - in this case it would be the torque converter clutch valve. The GM 5l40E transmissions have their problems and general consensus is that they will almost ALL go at between 80k-100k miles, so you're nearing the end of your transmission's life-span.
If you can, speak to John Mackie. Extremely knowledgeable and helpful.
Sorry - & good luck.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #18464 19th May 2010 10:29am
simonmanx
Big Cry Well im home and RR on a recovery truck lost all drive and I can hear a noise coming from the front in the bell housing. so is it the converter I need to change or the box too ?? I also had TRANS.FAILSAFE.PROG on the dash so guys any ideas .
Post #18491 19th May 2010 6:23pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Sorry to hear that mate. Hope the bill isn't too painful..... Trans failsafe is just the car saying that its detected a gearbox/ drive fault of some sort, and gone into limp mode.
Good luck with it Thumbs Up
Post #18500 19th May 2010 8:01pm
simonmanx
well its official torque converter and box wrecked!!! and only 30 miles from when it 1st felt odd so if you have a TD6 and its done 50,000 miles change your transmisssion filter and fluid NOW dont wait 30 miles like i have !! take it from me 50.000 miles then 100,000 and onwards for a cost of around £120 to 250 get it done instead of £1000s like i have !! Big Cry
Post #18664 23rd May 2010 11:59pm
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
I have had a 5 gearboxes in my TD6. Land Rover charge thousands.....
There are quite a few independent specialists around who will do a gearbox change for about £1600, for a drive (push) in service.
I guess being on the IOM may limit your choices, but if you can get over I can recommend a few!!
Post #18667 24th May 2010 6:56am
