Home > Technical (L322) > help!!
Welshdragon
help!!
Ok its raining again but I have a big problem, the FF is parked up and the key is out of the car, my brake lights are on and I cant turn the ignition on when replacing the key, I have taken the fuse out so not to flatten the battery, ( number 9) but still unable to unlock steering.
I had inadvertantly left my sunnroof open by about 2 " last night and water was on the rubber mats, is there a get you home mod so I can dry up things?
Please help as Im now stuck at flippin work Big Cry Big Cry Big Cry If it dont work.......burn it!
Post #222125 11th Nov 2013 9:41am
first thing is to disconnect the battery for about 20 minutes and then reconnect ..make sure you turn the steering wheel fully left then fully right after the reconnect. ... - .- -.
Post #222126 11th Nov 2013 10:00am
I think you may find your battery is substantially flat even though your brake lights are "on".
A jump start or battery charge should allow you to get the key to turn and start the car. Thumbs Up
Post #222130 11th Nov 2013 10:18am
^^^+1 Thumbs Up
Post #222131 11th Nov 2013 10:20am
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
search my posts had same fault turned out to be ignition switch not ignition barrel had to take center consul out to get to the thing. the switch comes off barrel ,take switch apart and use plenty of switch cleaner and paper towels then use some plus gas to lube up, take your time and save a few quid , had this prob over 12 months ago now ok have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #222136 11th Nov 2013 11:14am
+1 for flat battery, only takes a small drop to render the car immobile..... There is nothing that can't be fixed with a hammer😜😜
Post #222150 11th Nov 2013 12:00pm
Welshdragon
thank you all for the very quick reply's chaps, well I've had to leave FF at work as the battery was so low the even boosting off the discovery would not do a thing, not even able to unlock the ignition!
So now its on charge ( new one to be ordered very soon) but I need to dry out the electrics Big Cry , I have taken the side panels off and centre consel side panels but cant see many ecu's, found the headlight level and the other one next to the accelerator peddle but the seem all ok.
the channel either side of the seats where the main loom sits in is very wet, any ecu's further back that sit this low?
If only I can get the FF home could do more but with out it unlocking I cant even load her on the trailer!
Boy the joys of Green oval ownership.....nothing changes does it! Rolling with laughter If it dont work.......burn it!
Post #222206 11th Nov 2013 6:05pm
Welshdragon
well had the battery recharged and this morning on my break I fitted and ......the FF started up Thumbs Up I did the steering thing and just let it tick over for a bit before had to go back to work....BUT after my shift finished, 2 and half hours later......the ff didn't want to know, brake lights on again, battery had got flat AHHHH it did unlock doors on the key remote though.
Ok is there a reason for the ignition lock not able to release the battery has 12.4 volts, should unlock in my mind as its has done before with no problems, even when turning the engine off then take key out and replace in the lock disengages quickly.
I'm getting a new battery tomorrow so hoping it will unlock and nothing like its a once only turn key home jobby!
Grrrrr I'm now wondering if I did the right move by buying another green oval. If it dont work.......burn it!
Post #222419 12th Nov 2013 6:05pm
trainmanone
look at my post had the exact same problem its the switch on the bottom of ignition barrel needs stripping and cleaning with switch cleaner ,then smear of grease ,and wd40 take your time its an easy job once you have ignition switch/barrel out of car have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #222426 12th Nov 2013 6:50pm
Rosco
I had a myriad of problems, windows going down on their own, any door left open for more than a nano second, ignition sticking etc. Was trickle charging battery as I thought I had replaced 18 months ago after it had sat dead for a year with an "unknown" ignition issue (turned out to be the instrument panel), anyway I hadnt changed battery and was still running the original!!! God knows how it lasted.
New battery 6 months ago and (tempting fate) not one issue Thumbs Up 2013 L405 Autobiography Baltic Blue
2007 L322 Vogue Buckingham Blue
Post #222431 12th Nov 2013 6:55pm
Welshdragon
thanks guys, hoping its the battery ( 2 years old according to the date on it) , just need to get it back home, will look at the ignition lock too.
Not sure how it works but as the FF is now technically dead how does it know when the battery is reconnected that it remembers the transponder in the key?
I know, I know it a silly question Embarassed If it dont work.......burn it!
Post #222438 12th Nov 2013 7:06pm
Witchcraft Laughing
Post #222456 12th Nov 2013 7:51pm
Welshdragon
Big Cry
I'll have too put it on a stake and............... Rolling with laughter Rolling with laughter If it dont work.......burn it!
Post #222457 12th Nov 2013 7:59pm
Rosco
Craig Very Happy you have hit the nail on the head Very Happy Thumbs Up It belies normality Evil or Very Mad 2013 L405 Autobiography Baltic Blue
Post #222459 12th Nov 2013 8:02pm
DMRR
Mine is still running on the battery it was born with in November 2006..... Bow down Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #222537 12th Nov 2013 11:03pm
