Home > Technical (L322) > help!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35110 |
first thing is to disconnect the battery for about 20 minutes and then reconnect ..make sure you turn the steering wheel fully left then fully right after the reconnect. ... - .- -.
11th Nov 2013 11:00am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
I think you may find your battery is substantially flat even though your brake lights are "on".
11th Nov 2013 11:18am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
^^^+1 |
11th Nov 2013 11:20am |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
search my posts had same fault turned out to be ignition switch not ignition barrel had to take center consul out to get to the thing. the switch comes off barrel ,take switch apart and use plenty of switch cleaner and paper towels then use some plus gas to lube up, take your time and save a few quid , had this prob over 12 months ago now ok have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
11th Nov 2013 12:14pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8486 |
+1 for flat battery, only takes a small drop to render the car immobile..... There is nothing that can't be fixed with a hammer😜😜
11th Nov 2013 1:00pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
thank you all for the very quick reply's chaps, well I've had to leave FF at work as the battery was so low the even boosting off the discovery would not do a thing, not even able to unlock the ignition!
11th Nov 2013 7:05pm |
well had the battery recharged and this morning on my break I fitted and ......the FF started up I did the steering thing and just let it tick over for a bit before had to go back to work....BUT after my shift finished, 2 and half hours later......the ff didn't want to know, brake lights on again, battery had got flat AHHHH it did unlock doors on the key remote though.
12th Nov 2013 7:05pm |
look at my post had the exact same problem its the switch on the bottom of ignition barrel needs stripping and cleaning with switch cleaner ,then smear of grease ,and wd40 take your time its an easy job once you have ignition switch/barrel out of car have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
12th Nov 2013 7:50pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2571 |
I had a myriad of problems, windows going down on their own, any door left open for more than a nano second, ignition sticking etc. Was trickle charging battery as I thought I had replaced 18 months ago after it had sat dead for a year with an "unknown" ignition issue (turned out to be the instrument panel), anyway I hadnt changed battery and was still running the original!!! God knows how it lasted.
12th Nov 2013 7:55pm |
thanks guys, hoping its the battery ( 2 years old according to the date on it) , just need to get it back home, will look at the ignition lock too.
12th Nov 2013 8:06pm |
Witchcraft |
12th Nov 2013 8:51pm |
12th Nov 2013 8:59pm |
Craig you have hit the nail on the head It belies normality 2013 L405 Autobiography Baltic Blue
12th Nov 2013 9:02pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Mine is still running on the battery it was born with in November 2006..... Land Rover Addict
13th Nov 2013 12:03am |
