![]() | Home > Technical (L322) > Poor running |
Where there any other letter etc before the above numbers? |
Cash2 Member Since: 14 Jul 2012 Location: Essex Posts: 75 ![]() ![]() ![]() |
No letters just numbers from the IID,
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Injector number 4 is playing up.
Update to the problem, diagnosed as injector number 6 at fault part number MJY 0070
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 ![]() ![]() ![]() |
Try Dan @ duckworths... |
Thanks I have called and ordered from Duckworths. |
Guys - Had the injector number 6 replaced as diagnosed by a Land Rover garage by the same garage, collected the car on Wednesday drove home and used it yesterday all good, now suffering same symptoms as before injector replacement..
Have the fuel pumps pumps been checked? MY 2010 5.0 SC Galway green and sand interior!!
I do not think so, I will mention it to them when I take it back this morning.
Just used the IID and got the following fault codes - PCM Engine TD6 ECU.
Fuel pumps checked all OK, the gargae tested the FF for 36 hours and as soon as I took it home the same symptoms started again so back to the garage tomorrow.
As an update to the Poor running saga, I got the FF back this evening after the garage replaced a faulty wiring loom, all running well - I will post the exact details tomorrow when I get the full report from the garage.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
i wonder if your faulty loom is the same one as they replaced on wheeler dealers.. ... - .- -.
I did not see that episode, do you remember how long ago it was shown? |
