Home > General > Have you tried pulling the handbrake in an emergency stop? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
I was shown how to do this properly on the Range Rover Exhilaration Day (Search the forum for a write up on that).
14th May 2010 3:18pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
just a word of boring caution , never ever apply the handbrake while you are moving on Land / Range / Discovery which has a Hand brake which works on the transmission, not only will you break the back axle, but your gearbox is likely to suffer severe damage - as transmission H/B's work on the output shaft of the gearbox and not on the rear disc's / drums like a conventional car, you are also likely to lose control of the vehicle.
14th May 2010 3:59pm |
Can't remember, it all happened so quick, there was lots of beeping and then it was over! Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
14th May 2010 4:27pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1666 |
Above about 6mph the EPB switch activates the "service brakes" (i.e. the 4 corners) using ABS + traction control as necessary |
14th May 2010 4:42pm |
On a series LR it's a sure fire way of breaking your halfshafts. On my RR the HB uses drums on the back which barely hold the car still in a light breeze!
14th May 2010 9:00pm |
Turbo Tony Member Since: 06 Apr 2010 Location: London Posts: 243 |
Thanks... That's... err... reassuring, if I ever feel the need. Researching my first Range Rover purchase |
15th May 2010 7:35pm |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 |
Did it cure the noise? Mine have developed a screech when stopping once warm on a few occasions and its bloody annoying! TDV8 HST Sport **Current** 4.4 V8 Autobiography and 22" wheels **Gone** |
18th May 2010 8:58am |
I thought you had the electronic park brake on your car? |
18th May 2010 9:55am |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
err...
18th May 2010 11:07am |
Mac,
18th May 2010 7:11pm |
4 x Pads = £77.18p
18th May 2010 7:50pm |
