Home > General > Have you tried pulling the handbrake in an emergency stop?
I was shown how to do this properly on the Range Rover Exhilaration Day (Search the forum for a write up on that).
My brakes have been making odd noises, so on the basis they were on the way out, thought I'd give this a go in the real world. Found a nice straight road, no one else about for safety. 50mph, foot off the foot brake pedal and pull and hold the handbrake. release again just before a total stop.
Amazing how quick these things can stop Thumbs Up
PS: have also done this at 70mph.
NB: This was done on a car with the EPB, not the traditional version! Discovery 4 HSE
Post #18235 14th May 2010 4:18pm
Turbo Tony
That would scare the bejeezus out of me!
Out of curiosity, did the ABS function using the EPB? Researching my first Range Rover purchase
Post #18237 14th May 2010 4:25pm
Vogue
just a word of boring caution Razz , never ever apply the handbrake while you are moving on Land / Range / Discovery which has a Hand brake which works on the transmission, not only will you break the back axle, but your gearbox is likely to suffer severe damage - as transmission H/B's work on the output shaft of the gearbox and not on the rear disc's / drums like a conventional car, you are also likely to lose control of the vehicle.
Output shaft handbrakes are on Series LR's, 110's, 90's RR Classics and Discovery 1 and 2's etc
The Only exception to the above is in an emergency.
Post #18238 14th May 2010 4:59pm
Can't remember, it all happened so quick, there was lots of beeping and then it was over! Discovery 4 HSE
Post #18242 14th May 2010 5:27pm
Martin
Site Admin
Above about 6mph the EPB switch activates the "service brakes" (i.e. the 4 corners) using ABS + traction control as necessary Smile
Post #18247 14th May 2010 5:42pm
dan_uk_1984
On a series LR it's a sure fire way of breaking your halfshafts. On my RR the HB uses drums on the back which barely hold the car still in a light breeze!
I cant envisage any situation that would require the use of the e-brake.
Post #18259 14th May 2010 10:00pm
Turbo Tony
Thanks... That's... err... reassuring, if I ever feel the need. Researching my first Range Rover purchase
Post #18290 15th May 2010 8:35pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Re: Have you tried pulling the handbrake in an emergency sto
Did it cure the noise?
Mine have developed a screech when stopping once warm on a few occasions and its bloody annoying! TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #18405 18th May 2010 9:58am
I thought you had the electronic park brake on your car?
Post #18410 18th May 2010 10:55am
Fox
err...
Post #18414 18th May 2010 12:07pm
Mac,
no it hasn't and in fact there are a few more noises. It's definitely time for new pads and discs all round. I reckon they are still the original ones so at 40k have done enough. The discs are well ridged and in need of the bin.
For a laugh I'm going to call some dealers tomorrow to see just how expensive they can quote! Discovery 4 HSE
Post #18444 18th May 2010 8:11pm
4 x Pads = £77.18p
Disc's = £41.33p
Sensor Assy = £8.78p
Wiring Assy = £10.53p
Brake Lining Kit = £28.95p
LR Dealership up here interested to see the comparison ............... Thumbs Up ====================================
Post #18449 18th May 2010 8:50pm
