Home > Technical (L322) > changing power steering fluid
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi all
Any one changed there power steering fluid in there FFRR yet. Mine needs topping up but has yellow fluid in it at the moment while the official Land Rover fluid i have purchased is green Censored and dont want to mix the 2. Nothing in RAVE on how to drain and refill.
Matt
Post #219268 28th Oct 2013 11:10am
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Draining and replacing mine is also on the to do list.
I haven't had a proper look at it yet though.
Post #219269 28th Oct 2013 11:13am
srpara
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I would think all you need to do is undo one of the pipes on the rack and let the fluid drain out then do it up and refill with fluid and bleed system by turning the wheel from lock to lock a few times. (I'm sure Craig will put me right if the above was a load of Censored Very Happy )
Post #219279 28th Oct 2013 11:43am
paul271
I was also going to drain it again after a week or two in an effort to flush the the rack.
Post #219287 28th Oct 2013 12:11pm
this might help,
http://www.fullfatrr.com/forum/post101719.html ... - .- -.
Post #219290 28th Oct 2013 12:17pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Mine is yellow told its cold climate stuff thats it.
I was going to change mine as i thought the steering was harder than it should be.
On closer inspection i saw the steering u/j's on the shaft were dry so oiled them up and its a lot lighter. Razz
Post #219298 28th Oct 2013 12:41pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I changed mine a few months ago - it's very simple to do - but needs two people.
Just remove the reservoir from its bracket, then remove the return pipe and put it into a bucket or large bottle. Keep your finger or thumb over the hole in the reservoir where the return pipe connects and fill the reservoir with new fluid.
Get your glamorous assistant to start the engine - now pour the fresh fluid into the reservoir until the fluid coming from the return pipe into the bucket is clean and the same colour - to be sure put another 1/2 litre through then switch off the engine.
The fluid will pump out very fast indeed - so be ready with the bottle to start pouring the fresh in the moment the engine is started - it will empty the reservoir in about 5 seconds!
Then put it all back together, top up the reservoir, start the engine, top up, lock to lock on the steering and top up again if needed. Close bonnet and declare a good job done.
Post #219306 28th Oct 2013 1:16pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
If you are changing the fluid type a proper flush as described is preferable.
However, I simply sucked the old fluid out of the reservoir and topped up a number of times. I used twice the published volume of the system. I noticed a difference as it had not been replaced before. All has been well since.
Mine was green fluid I think. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #219331 28th Oct 2013 3:51pm
spanielzrus
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
I managed to do a full flush my TD6 steering fluid by using an engine oil vacuum suction unit. £15.00 on a well known auction site.
1: Remove front engine cover and air intake to fuel cooler.
2: Cover alternator to avoid spills damaging it.
3: Remove reservoir cap and suck out what can be seen in the reservoir.
4: Disconnect the return pipe on the side of the reservoir (small pipe) and plug the inlet.
5: Using vacuum pump connect it to the return pipe and ensure it is sealed as best you can. I used an intermediate size rubber tubing to ensure a good seal.
6: Pump out old fluid whilst keeping reservoir topped up.
7: When fresh coloured fluid appears in vacuum tank stop pumping by disconnecting vacuum hose.
8: Connect up all pipes again.
9: Mop up any spills.
10: Remove cover from alternator and refit engine cover.
11: Start engine and bleed by turning from side to side a few times to ensure any air drawn in has been expelled.
Took me about 45 mins-1hour. Took about 1 litre of fluid to flush through.
Post #546782 11th Mar 2020 10:47am
nino_nino
https://www.fullfatrr.com/forum/topic47852.html 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #546815 11th Mar 2020 4:57pm
spanielzrus
Nino,
Your post is way better than mine and the photos are great! Thumbs Up
I don't have the vacuum set up you have so had to resort to a smaller cheaper DIY home fix.
thanks again. Smile
Post #546818 11th Mar 2020 5:05pm
