Home > Technical (L322) > changing power steering fluid |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 |
Draining and replacing mine is also on the to do list.
28th Oct 2013 11:13am |
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 |
I would think all you need to do is undo one of the pipes on the rack and let the fluid drain out then do it up and refill with fluid and bleed system by turning the wheel from lock to lock a few times. (I'm sure Craig will put me right if the above was a load of ) |
28th Oct 2013 11:43am |
I was also going to drain it again after a week or two in an effort to flush the the rack. |
28th Oct 2013 12:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
this might help,
28th Oct 2013 12:17pm |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 |
Mine is yellow told its cold climate stuff thats it.
28th Oct 2013 12:41pm |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
I changed mine a few months ago - it's very simple to do - but needs two people.
28th Oct 2013 1:16pm |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
If you are changing the fluid type a proper flush as described is preferable.
28th Oct 2013 3:51pm |
spanielzrus Member Since: 20 Aug 2019 Location: Dunfermline Posts: 8 |
I managed to do a full flush my TD6 steering fluid by using an engine oil vacuum suction unit. £15.00 on a well known auction site.
11th Mar 2020 10:47am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
https://www.fullfatrr.com/forum/topic47852.html 2012 TDV8 Black Edition
11th Mar 2020 4:57pm |
Nino,
11th Mar 2020 5:05pm |
