Home > Wheels & Tyres > Hankook Ventus ST 255/55/19's, anybody used these?
Discotigger
Got a full set of Hankook Ventus ST's fitted to my FFRR in the last couple of months and have now got a weird vibration through the steering. Had the wheels rebalanced twice...but not sure the tyre fitters have done a proper job of rebalancing.
Getting my Indy to swap the wheels for a set of alternatives off another FF to see if that cures the vibration, but not getting that done till next Friday.
Just wanted to find out if there's anybody out there who's had these tyres fitted and what the general feedback is.
Vibrations aside, the tyres seem really good. Excellent grip in wet and dry, quiet and seemingly hard wearing. I'm hoping it's just a proper balancing job required to cure the prob, but would like to hear any feedback from the good folks on this forum. Bow down Bow down
Post #218714 25th Oct 2013 6:05pm
this might be a silly question but are the tyres fitted in the correct direction... ... - .- -.
Post #218719 25th Oct 2013 6:31pm
Discotigger
Not a silly question Stan... Bow down
I thought that myself at first, but they're definately fitted in ihe right direction! I've checked...and checked...and checked...LOL!! Laughing
Post #218728 25th Oct 2013 7:01pm
Googsy
Maybe one of the tyres is faulty happened one of my nexens havent changed it yet but getting vibration through steering wheel.It was only apparent when spinning on the balancing machine. Mine is front left that needs replaced. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #218734 25th Oct 2013 7:48pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
try swapping fronts to the rear and give it a run see if anything changes.
On a balancer you will see any tyre imperfections on the spin cycle
Post #218744 25th Oct 2013 8:31pm
Hankook Ventus should be OK....
Post #218760 25th Oct 2013 9:27pm
RR2008HSE
Remember, the FFRR needs to be in high tolerance mode (done using IID or similar) for alignments. It may be the same for dynamic balancing.
On the easy side: Did you check to see if any wheel weights fell off? (Sorry if that's too basic, but it occurred that it may not be something complicated.)
Post #218783 26th Oct 2013 12:48am
Discotigger
Thanks for the replies guys, I'm getting the tyres checked out on Friday at my local Indy garage. The owners have a 2003 FFRR and they're going to swap the wheels over from mine to check them out.
Hopefully it's just a proper balancing job that's required to fettle them.
I did check that none of the weights had fallen off, the wheels seem okay...but we wont be able to tell until the swap-over. Till then it's just a case of living with the vibration.
I've used Hankook tyres before...got the V12 EVOs on my Mondy ST220, with the 225/40/18 alloys, and had the Dynapro ATMs on my old 300TDI Disco, they've always been good tyres. That said, there's always the chance of getting a bad tyre...or even a batch...as I got all four tyres from the same spot.
Will update on Friday. Thumbs Up
Post #218842 26th Oct 2013 10:24am
BIGMAMMA
England 2017 Range Rover Autobiography SDV8 Loire Blue
I've got 20" version of Hankook Ventus (275.45R20) on my full fat. Been on for over two years and have done over 40,000 miles to date. Very happy with them, but edges just going off now. Hope you sort your vibration problem!
Post #219154 27th Oct 2013 8:23pm
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
I have been running these on my Rangie for approaching 40,000 miles.Like bigmamma above mine are just starting to go off now and will have to be changed soon.Good mileage for a tyre on a heavy jeep though.
Great tyre,great value for money,quiet,hardwearing and good in the wet,snow and greasy roads.
I had a similar problem with a different brand tyre on my other car,multiple times back for balancing which didnt work as had a noticeable vibration at motorway speed.The tyre fitter replaced the tyre and immediately vibration went away.They said the odd tyre will have a manufacturing defect and throws the tyre out of balance that no amount of counterweights will fix.When we looked at the inside of the tyre there was a flaw on the inside of the tyre and there was the problem..!!
Other issues it could be are tracking/geometry,warped wheel or brake discs maybe..??
Post #219891 31st Oct 2013 7:36am
Discotigger
Got the wheels swapped over on the FF last friday, but didn't manage to get a proper run out on the tyres as the weather was awful. Couldn't tell much from the run, too much water on the roads to see if the slight judder had stopped or not.
My local indy reckons it's deffo a balance issue though. Gonna get the wheels and tyres match balanced (and checked out for defects as well) at my local stealers when I get the Hybrid TV sorted, a week come Friday.
So will give a final update at the end of next week.
Post #221015 5th Nov 2013 9:02pm
BIGMAMMA
pics taken last week, 20" with 40,000 miles - front nearside. I'm happy!
Post #221731 8th Nov 2013 9:14pm
40,000 miles!!!! Shocked
In the past year I've bought 5 sets of tyres.
Summer tyres for the RR
Winter tyres for the RR
Winter tyres for the VX
Summer tyres for the VX
Tyres for the SP2 motorcycle (only 2!)
If I get 40k from each of those sets, given the number of cars/bikes I have, the fact that I only use each set half a year, and my mileage, I shouldn't need to buy another set for....calculating.....16 years. Very Happy
...no wait, they expire after 8. Sad
Post #221749 8th Nov 2013 9:56pm
Discotigger
Yep, gotta agree with you, BIGMAMMA. They're good tyres, I've used Hankooks on my Mondeo ST220 and on my old Disco 300 TDi and they've been bloody good!!
I am just hoping that my slight judder is just cos the wheels and tyres need match balancing, they've been great in the crappy weather recently...especially when the roads have been waterlogged (flooded!!). Will update on Friday once the stealers have had a go doing a match balance.
Post #222056 10th Nov 2013 7:15pm
Discotigger
Update...got the tyres match balanced today and what a difference. Lovely and smooth now.
Happy days!! Very Happy Very Happy
Post #223165 15th Nov 2013 1:16pm
