![]() | Home > Wheels & Tyres > Hankook Ventus ST 255/55/19's, anybody used these? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
this might be a silly question but are the tyres fitted in the correct direction... ... - .- -.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Not a silly question Stan... |
Maybe one of the tyres is faulty happened one of my nexens havent changed it yet but getting vibration through steering wheel.It was only apparent when spinning on the balancing machine. Mine is front left that needs replaced. Present :2008 TDV8 HSE
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
try swapping fronts to the rear and give it a run see if anything changes.
Hankook Ventus should be OK.... |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Remember, the FFRR needs to be in high tolerance mode (done using IID or similar) for alignments. It may be the same for dynamic balancing.
Thanks for the replies guys, I'm getting the tyres checked out on Friday at my local Indy garage. The owners have a 2003 FFRR and they're going to swap the wheels over from mine to check them out.
BIGMAMMA Member Since: 28 Oct 2012 Location: LEICESTERSHIRE Posts: 175 ![]() ![]() ![]() |
I've got 20" version of Hankook Ventus (275.45R20) on my full fat. Been on for over two years and have done over 40,000 miles to date. Very happy with them, but edges just going off now. Hope you sort your vibration problem! |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
I have been running these on my Rangie for approaching 40,000 miles.Like bigmamma above mine are just starting to go off now and will have to be changed soon.Good mileage for a tyre on a heavy jeep though.
Got the wheels swapped over on the FF last friday, but didn't manage to get a proper run out on the tyres as the weather was awful. Couldn't tell much from the run, too much water on the roads to see if the slight judder had stopped or not.
pics taken last week, 20" with 40,000 miles - front nearside. I'm happy!
40,000 miles!!!! |
Yep, gotta agree with you, BIGMAMMA. They're good tyres, I've used Hankooks on my Mondeo ST220 and on my old Disco 300 TDi and they've been bloody good!!
Update...got the tyres match balanced today and what a difference. Lovely and smooth now.
