![]() | Home > Maintenance & Mods (L322) > Gearbox Megaflush |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
Whilst I'm unconvinced by much of the spiel, the supposed benefit of a Megaflush is that it changes all the ATF - unless you're draining the converter separately, just dropping the sump isn't going to do that. |
Thanks Trommel/ all... In our case the Master Tech says he saw no evidence - either through driving the car or of shavings/ glitter or other visible alarms - that the gearbox was anything other than A1 and he seemed pleased that what he changed on ours was a good pro-active preventative and maintenance process at low miles anyway. Happy |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
ideally you would do the whole lot really change all the oil, not only half of it (7 liters) + filter/sump/rubber gasket element + 21 bolts holding it all together. This would be perfect, but doesn't seem to be the case, hence Craig Poll. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Changing the oil and not changing the filter would be akin to having a bath and putting your dirty underwear back on |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
@47P2 |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
This is one of those jobs that needs to be done by some body that does it properly.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
And that's not being argued... The point is this, the flush is being performed by most without changing the filter. And it's this practice I do not agree with! And I wanted to make members aware of... Craig |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
When you change your engine oil you fit a new filter for me its a no brainer no new filter fitted then its a waste of time i think.
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
I had mine done when the plastic sump became cracked. I had it replaced, including bolts, and took the opportunity to replace all the fluid and the filter. cost nearly £600.
I have had a Range Rover in one for or another for 15 years.
£600 ![]() |
Crikey indeed. It was the job that made me seriously rethink who does what in future. Now I do some jobs and an independent does some. Very little goes to the main dealer. This forum is invaluable for helping me to decide who does what.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
£600.00
Something to point out here though. That "Filter" which everyone's going on about is actually a STRAINER !!
