Home > Technical (L322) > Stupid beeping... why are you so unclear? |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
5 beeps sounds like a tracker device. It's in the right place for one too. These are normally removed if you have not been supplied with the details or tag......
7th May 2010 3:39pm |
topgeartowers Member Since: 23 Mar 2010 Location: London Posts: 82 |
Thats super helpful - I was given two tracker-style tags (smaller but fatter than a credit card) but no documents with it. There was a telephone number on them, which I was tempted to call.
7th May 2010 4:55pm |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
topgeartowers you definatley have a tracker fitter check this link you will probably have a navtrack system
7th May 2010 5:20pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi mate,its a cobra navtrac tracker, i had this on my car for a while but had 3 beeps until i threw away what i thought was a garage tag, small rectangle black plastic pad, then i got the 5 beeps. you can contact them and they will reconnect it and supply new tags, its around £260 a year for the full package, they will phone you if the car is moved with out the present of the tag in the car...
7th May 2010 10:16pm |
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 |
I went through the same emotions as you a few weeks ago - Call Cobra, give them your reg and they will confirm it is a tracker. You can pay to have it re-enabled and the five beeps will reduce to three but not switch off.
7th May 2010 10:19pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
Rowly,
8th May 2010 9:49am |
Lookers Park Royal Member Since: 30 Apr 2008 Location: London Posts: 463 |
If it has a Navtrak then it will beep a few times if it has not been able to locate the ADR tag (credit card transponder). If the system was live and had a subscription then at that point NavTrak would recieve a text message from the car and they would in turn contact the customer.
8th May 2010 3:43pm |
It's not a bug/error - it's they way PDC works on that model! Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
8th May 2010 6:33pm |
Thrasher - Just read it properly, yes you're quite right! I guess it assumes you are still manouvering. James |
8th May 2010 7:52pm |
Thanks to any and all for the fast replies - forums like these are just fantastic help for new owners.
9th May 2010 7:13pm |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
Don't wrap yours - Wrap his!
9th May 2010 7:42pm |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
Top Gear Bloke,
9th May 2010 8:37pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Aaah! I was slow here, so I'm guessing Rowly is Christopher R. from the Top Gear mag that I read, never actually made the connection for some reason until you mentioned Hammond. (Mags great by the way, have subscribed for several years now). Steve
9th May 2010 10:52pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3749 |
perhaps pink ? |
10th May 2010 9:54am |
