Home > Technical (L322) > Can't open the car
Page 4 of 4 <1234
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
Edit: Problem partially fixed
You maybe right, but I guess that if i turn on the ignition it would start ?
In my opinion, we can't open the car using interior handle when the car is super-locked in order to prevent the robbers to opening the car, but with the correct key, I can't see any reason to no be abble to release the super lock bu turning on the contact.
Post #216782 15th Oct 2013 9:41pm
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
The worry is you do not know for sure what has failed in the key & the car must recognise the chip in it to start Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #216784 15th Oct 2013 9:45pm
Fr_Raf
You're right.
In fact, the mechanism start to not work correctly sunday evening during my journey from Lyon to Paris. The mechanism did'nt work properly when I started the journey, same thing when I stopped to fullfill the LPG. I can feel the mechanism working, but the little part in the door did not moving as usual (it is the reason why, maintaining the key turned on the left I discovered that windows openned all together as with the keyfob button).
When I arrived at the hotel in Paris, I locked the car with the key, all the doors wer locket at the same time except the driver's one. I re-opened the car, and pushed manually the door button to lock the driver door, and closed the other doors using the key. (I turned the key on right for few sedonds to close all the windows)
I was very far to imagine that in the morning, I would not be able to unlock at least the three other doors and tailgate.
But before the mechanism totally failed, the key was working correctly to start the car. I hope there is a poor probability that the door mechanism and the ignintion have dead at the same time ?
Post #216790 15th Oct 2013 9:59pm
having re-read all you have said the drivers door may not be super locked. Try hooking some thing over the drivers door handle & see if it unlocks Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #216792 15th Oct 2013 10:35pm
avoir relu tout ce que vous avez dit la porte du conducteur peut ne pas être super verrouillé. Essayez de brancher quelque chose sur la poignée de la porte du conducteur et voir si elle déverrouille Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #216793 15th Oct 2013 10:35pm
Fr_Raf
I don't agree, because even if i locked the driver's door with the door's button, immediately after, I turned the key on right to lock the 3 other doors, and close the windows, I think then, that i had a super-lock effect on the car, and if super-locking the car, it certainly disabled the interior handles, and then, the driver's one too, don't you think ?
As I tried with a wire, I didn't feel any resistance with the driver's handle, making me thinking that this one is disable too...
Post #216795 15th Oct 2013 10:43pm
Fr_Raf
Thank you to translate what you wrote, it is quite easier to me to understand some messages as english is not my first laguage.
I hope my English is not so poor as you have problem to understand what I want to tell you all.
My appologies if I killing your language Embarassed Embarassed
Post #216796 15th Oct 2013 10:47pm
I dont envy you at all & I hope someone can come up with a solution that helps you. Apart from asking a 17 year old in a hoody that could probably drive it away in 30 seconds Sad Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #216797 15th Oct 2013 10:50pm
Fr_Raf
Laughing
And in the area of Paris where is my hotel, approximatively at about 500 meters from Pigalle, I could find many specimen of guys you are talking about Very Happy but if I can avoid that, I would prefer Whistle
Post #216798 15th Oct 2013 10:58pm
Fr_Raf
does one of you went light a candle in a church ?
I can't sleep, then I went to the car, and even if I did not feel something when I tried to open the car with wire hooked to the interior drivers handle, I tried to move the exterior one, and miracle, the door opened.
You were right Mike & the mechanics, driver's door was not super locked.
I will synchronize my keyfob tomorrow, and cross my fingers to make it synchronize easily.
Thank you all for your advices, your ideas, it was realy helpful. Bow down Bow down
Very Happy
unfortunately, I'm just a man and not a woman, then I can't to many think at the same time, and driving in Pigalle and seeing girls at the same time is quite dangerous as there is a big concentration of sexy girls in a square meter. Whistle
Post #216807 16th Oct 2013 2:09am
Fr_Raf wrote:
Laughing
Now go and celebrate in the Pigalle Whistle Shocked Thumbs Up (i used to stay near there a lot in my younger employed days) eye opening place! Shocked
Post #216822 16th Oct 2013 8:21am
i was going to suggest the emergency tailgate release but i'm a bit to late..
glad you've opened it.. Thumbs Up ... - .- -.
Post #216827 16th Oct 2013 8:49am
Hooray Thumbs Up Very Happy
Post #216836 16th Oct 2013 9:32am
Fr_Raf
Cam-Tech-Craig wrote:
Fr_Raf wrote:
Laughing
Post #217133 17th Oct 2013 3:36pm
Indeed Thumbs Up
Post #217209 17th Oct 2013 6:34pm
Page 4 of 4 <1234
