![]() | Home > Technical (L322) > Can't open the car |
Fr_Raf Member Since: 20 Nov 2010 Location: Lyon - Paris Posts: 147 ![]() ![]() ![]() |
I'm affraid smashing the window is the only solution I have... I'll choose the small one on rear door, my arm would be long enough to open the rear door from interior of the car. |
I tried too... with no success ![]() |
You're right, but I'm affraid they tell me to call a locksmith instead of smashing my car in a public area ![]() |
Isn't it the aftermarket cover he had on the driver door he had ? |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Honestly can't remember - just seem to remember some discussions that both doors have locks on them, but the passenger one is covered (so that the same doors and handles can be used for left hand drive and right hand drive vehicles). |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
A locksmith may be a cheaper option....... There is nothing that can't be fixed with a hammer😜😜
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
2010 onwards UK cars have them on the passenger side with a cover (like the sport/disco 3) the earlier FF's have them on the UK drivers door ![]() That's where you have seen/read this ![]() |
Then, there is no chance i'd find a key hole on the passenger door if I remove the cover ?
Ipslore Member Since: 21 Apr 2013 Location: St Helier Posts: 39 ![]() ![]() ![]() |
I recall if this is the BMW key types then the doors are super locked on the key or the fob which disables the interior door handles and the dash button. If yours is a 2004 I thought there was a release in the upper rear tailgate but you would need to carefully wedge the tailgate to create a small gap to get to it and maybe pull the weatherstrip away slightly and use a hooked wire or suchlike. Someone may be able to post a link to a 2004 handbook as yours is in the car...?
Aha - I knew I'd seen something about it! Cheers. |
^^^ +1
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 ![]() ![]() ![]() |
I wonder if landrover power up an impact sensor which automatically unlocks the doors in an accident? Would not want to try it without some good wiring diagrams as would be very expensive if it fired all the airbags. I know ford had a problem with some of their cars being stolen by smacking the bonnet in the right place with a tennis ball & activating the sensor. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
Well, to summarize:
Are you sure it will start off key as superlocked, I would at least be taking some prof advice from landrover assist as no point just damaging your car for no purpose Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
