![]() | Home > Technical (L322) > 2007 Xenon Reddish Glow |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Gents,
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
Has it always been like this if so might have aftermarket bulb fitted.
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
Exactly what Daveo suggests, should be a simple job and give you a definite answer. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
+1 |
Thanks! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35659 ![]() ![]() |
take this opportunity to get 2 6000k replacements bulbs [ebay about £30 for the pair] and keep the good one for spare. ... - .- -.
Good advice, Stan. I shall. |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Would agree with Daveo on this one.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
I always understood that xenons change their colour output as they degrade with it being much more noticeable just before they fail. Tom
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 911 ![]() ![]() ![]() |
Suggest replacing your bulb before it fails completely - this is exactly the sympton I had (although on a BMW 3 series) and the eventual bulb failure damaged the ballast which then also needed replacing, £££. |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
I suggest 4300k as this colour temperature provides the greatest illumination. 4.4 TDV8 Vogue Baltic Blue MY11 |
I ordered 2 x 6000k ones yesterday and should be getting them later.
4300k is more yellow than 6000k
