Home > Technical (L322) > 2007 Xenon Reddish Glow
Gents,
I've noticed a reddish glow from my nearside (passenger-side) headlight this morning. Right headlight in the pic below and clearly seen in the reflection on the bumper.
I'm assuming it's a bulb on its way out, but any informed opinions before I jump to conclusions?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Si. <This is my name.
Post #215360 9th Oct 2013 6:52am
daveo
yes i would say its the bulb, swap it to the other side to see if its the bulb and rule out the ballast unit V8 facelift Range Rover Autobiography 22" wheels.
Post #215362 9th Oct 2013 7:16am
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Has it always been like this if so might have aftermarket bulb fitted.
Not all bulbs give off the same light so best to change in pairs or go genuine ones
Post #215371 9th Oct 2013 8:21am
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Exactly what Daveo suggests, should be a simple job and give you a definite answer.
Post #215372 9th Oct 2013 8:31am
+1 Thumbs Up
Post #215389 9th Oct 2013 9:45am
Thanks! Thumbs Up
It's only been like this since this morning and was perfectly fine before that. Si. <This is my name.
Post #215393 9th Oct 2013 9:52am
take this opportunity to get 2 6000k replacements bulbs [ebay about £30 for the pair] and keep the good one for spare. ... - .- -.
Post #215402 9th Oct 2013 10:51am
Good advice, Stan. I shall. Thumbs Up Si. <This is my name.
Post #215414 9th Oct 2013 11:51am
Prop
Would agree with Daveo on this one.
Still its a very odd type of problem, I wonder if anyone else has suffered this type of bulb failure?
Post #215415 9th Oct 2013 11:53am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I always understood that xenons change their colour output as they degrade with it being much more noticeable just before they fail. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #215543 9th Oct 2013 7:22pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Suggest replacing your bulb before it fails completely - this is exactly the sympton I had (although on a BMW 3 series) and the eventual bulb failure damaged the ballast which then also needed replacing, £££.
Post #215592 10th Oct 2013 4:21am
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
I suggest 4300k as this colour temperature provides the greatest illumination. 4.4 TDV8 Vogue Baltic Blue MY11
Post #215755 10th Oct 2013 11:07pm
I ordered 2 x 6000k ones yesterday and should be getting them later.
What's the difference between those and the 4300k?
Sorry for the rather uninformed question. Embarassed Si. <This is my name.
Post #215762 11th Oct 2013 5:52am
4300k is more yellow than 6000k
5000k is the closest to white you can get but these are very hard to find..
6000k has a slight blue tinge to it and it is very very slightly less brighter...
i found because the 6000k light is whiter it 'looks' like the road is more illuminated than the 4300k ..
just put one 6000k in and you'll see the difference.. ... - .- -.
Post #215797 11th Oct 2013 8:05am
Will hopefully find out later. Si. <This is my name.
Post #215801 11th Oct 2013 8:10am
