Home > Maintenance & Mods (L322) > Tailgate catches - oily?
hughjayteens
2005 Range Rover Vogue Td6 Java Black
Hi all,
My car has very greasy/oily talgate catches and I am worried someone will get dirty pants if they lean against them! I can't see any reason why anything other than the inside of the release catches need to be lubed so am I OK to give the bodywork and support cables a good clean up?
Cheers
Chris
Post #17791 4th May 2010 2:12pm
Vogue
no lube on mine, prefer mine dry(ish) Cool
just keep it clean, wipe over every so often with rag & WD40 - removes most of the poo
Post #17793 4th May 2010 2:22pm
dan_uk_1984
Re: Tailgate catches - oily?
hughjayteens wrote:
Hi all,
Cheers
Chris
Well first of all if people are standing around your rear end in nothing but their pants then you're doing it wrong, tell them to put some trousers on!
And second, there should be a light coating on the locking mechanism, but it shouldn't be dripping, someone may have got carried away whilst lubing up.
Post #17795 4th May 2010 2:33pm
dan_uk_1984 wrote:
hughjayteens wrote:
Hi all,
Cheers
Chris
This thread is all going wrong! Discovery 4 HSE
Post #17797 4th May 2010 2:49pm
Vogue
where's the soap Shocked
Post #17804 4th May 2010 3:46pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Twisted Evil I find plenty of lube is always required when dealing with the backdo....... oh!
Whistle
Yes - give them a quick clean Thumbs Up
Post #17825 4th May 2010 6:14pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
DON'T LOOK! Its a trick... he'll ask you to pass it next Shocked
Post #17826 4th May 2010 6:14pm
delamo
Rolling with laughter Rolling with laughter Rolling with laughter
Post #17827 4th May 2010 6:20pm
