Home > Maintenance & Mods (L322) > Leak but from what?
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Leak but from what?
Been away for a week and under the car towards the front it's been dripping oil onto my drive. Traced where the oil is dripping from, it's towards the front of the car just back from the front tyres in the middle from a flat plastic looking plate. No idea what it is! Off to the garage then! Welcome home Thumbs Up
Post #212727 27th Sep 2013 3:19pm
pld118
This post was about a leak that included a leak coming out through the undertray. The tray was removed and 3 leaks sourced/ repaired, all as per the below thread for your assistance:
http://www.fullfatrr.com/forum/topic20141.html?highlight=leaking
The leaks in our case were -
• Oil Leak - Engine - visible via discharge out of under tray holes. On closer inspection and stripping components, this was reportedly attributable to the front offside driveshaft seal which was replaced.
• Oil Leak - Front diff - diff was weeping/ had a teardrop type leak. Pinion seal. Replaced the actual front diff.
• Gearbox Sum Pan - Oil leak. Visible/ sump and surrounding areas looked wet. Replaced the actual gearbox sump and the sump seal which involves draining existing oil, replacing with new oil and new filter (this equates to a gearbox service. The new oil & filter should help to prolong gearbox life).
Hope it's something simple Thumbs Up
Post #212728 27th Sep 2013 3:24pm
dirtyharry
Mine was leaking from the transmission oil cooler AND the left bank valve cover gasket. Shocked Cheers
Greg
Go ahead punk, make my day........
Previous vehicles:-
Far too many to list (in excess of 45!)
Post #212729 27th Sep 2013 3:35pm
crookedm
Oh Lordy! Thanks for the replies guess this is like googling something medical you suspect.
Post #212731 27th Sep 2013 3:40pm
crookedm
Ok so it's the gearbox sump as the component with slight wetness on is the one in pld118's last picture. Also underneath on the plastic cover it says zf (after crawling underneath).
More news when I get it!
Post #212820 28th Sep 2013 7:49am
crookedm
Just booked my car out of a main dealer and into and indie by me;
Main dealer wanted £461 to replace the leak culprit, the gearbox electrical connect sleeve. So off to Ian Barclay in Birkenhead. Thanks Mark for heads up.
Post #213484 1st Oct 2013 7:47pm
