Home > General > new owner looking for advice |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1242 |
When we got out first RR (1987 Classic) we were told that if a Range Rover doesn't leak oil there is a problem with it!! |
1st Oct 2013 9:44am |
clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51 |
If you've not got a coolant leak if may not have the correct mix of anti-freeze and water,have your local independent check it,if the car senses its a weak mix it will give a low coolant message on the dash.needs to be 50-50 mix |
1st Oct 2013 7:02pm |
samp5679 Member Since: 25 Sep 2013 Location: houghton le spring , north east Posts: 26 |
I will check this , can't see any leaks plus level is good , maybe sensor failure as I have read its common fault , what is the preferred coolant anyone??? |
1st Oct 2013 7:07pm |
When i change mine i use o.a.t(organic acid technology) its usually orange in colour,as you dont know whats in yours give it a good flush through to remove the old as not all anti-freeze mixes together. |
2nd Oct 2013 11:45am |
well 1 week and we have coolant light electric seats and steering wheel only work when they want and now radio wont come on great ! any ideas |
6th Oct 2013 8:44pm |
Check both cubby boxes in the boot for water in the infotainment gubins and the fuse box on the other side,pull the plugs out and look for corrosion,if none get a diagnostics check done see if any codes come up.
6th Oct 2013 9:33pm |
swan vesta way rounds good at min , no water ingress bone dry , turned sat nav on working but with no audio |
6th Oct 2013 9:52pm |
