Home > General > new owner looking for advice |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 |
ask for gas cert you need it for insurance if anything happens |
26th Sep 2013 8:04am |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 |
check it has had the front dif recall replacement
26th Sep 2013 10:54am |
Is the car home yet might pop and have a look tonight drop me a pm with tel no or post code mate |
27th Sep 2013 3:41pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2640 |
Trim strips from main dealer only , contact Dan , get his number on speed dial ! |
27th Sep 2013 4:07pm |
Just called up to see it will be loads better once he gets it cleaned and polished up |
27th Sep 2013 6:25pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
As we all know cosmetics count for nothiong, they can be sorted easily, although not a nice experience for a newbie 2013 L405 Autobiography Baltic Blue
27th Sep 2013 6:45pm |
samp5679 Member Since: 25 Sep 2013 Location: houghton le spring , north east Posts: 26 |
car going in to range rover main dealers for a once over tomorrow |
27th Sep 2013 6:49pm |
Fingers crossed, as long as OK mechanically then it will be worth it, my L322 has been in hospital for 3 weeks just to get the F ing airbag light out, but I still wouldnt change it 2013 L405 Autobiography Baltic Blue
27th Sep 2013 7:14pm |
inspection completed and road test by land rover technician at stratstone dealers all happy days drive good no faults bar low break pads on rear bodywork next week pic to follow |
28th Sep 2013 1:55pm |
Good to hear it is technically sound, looks are relatively easy to fix up. Bit of elbow grease with the detailing products and tools and a car can look a million dollars after a day of hard work.
28th Sep 2013 1:58pm |
clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51 |
Samp5679
30th Sep 2013 6:40pm |
I will post pics just as soon as I have found out were all oil is coming from on my drive and check coolant level message keeps popping up ,, not bad for 4 days ownership |
30th Sep 2013 7:59pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Green ovals, no mater what kind always leave there make on the drive......Its only marking its territory If it dont work.......burn it!
30th Sep 2013 8:24pm |
Is it saying it when you first start it up on your drive, if so might just be the angle its sitting at try and turn the car round and see if that changes anything. Or has it lost any water, if so get a pressure test on it and see if its just a hose leaking. |
1st Oct 2013 7:43am |
