Home > Technical (L322) > Suspension fault |
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 |
Have you started the car the next morning ?
22nd Sep 2013 9:07am |
They all settle and if ground in not completely flat car will level so different measurements either side! |
22nd Sep 2013 9:09am |
Jdhall78 Member Since: 11 May 2013 Location: Surrey Posts: 10 |
Hi Thanks for the quick reply
22nd Sep 2013 9:12am |
Should not have licked it
22nd Sep 2013 9:15am |
haha just spotted that i knew thats where i went wrong |
22nd Sep 2013 9:16am |
so any idea what could be causing the messages? |
22nd Sep 2013 9:23am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
have a read/search in the tech and maintenance sections for eas and suspension faults, there's loads on this subject .. .. ... - .- -.
22nd Sep 2013 9:27am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
If you drop your fattie down to access mode then raise it to off road height does it go up ok? Does it say "raising slowly"?
22nd Sep 2013 9:33am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8659 |
^^ should raise smoothly, best to do it after a run, as the compressor will have fully charged the air reservoir. Once you have used all the air up it will go up slowly, so dont expect to repeat access to offroad over and over again without it displaying raising slowly.
22nd Sep 2013 11:00am |
Ok just went on a 70 mile run no issues until 58 miles then suspension inactive max speed 30mph no lights on height selector.
22nd Sep 2013 12:03pm |
see if you can find someone local to clear your fault codes first... free use of "RSW" all comms to anyone nearby |
22nd Sep 2013 2:10pm |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 |
Yes there is one only 5min from you Its a really good one Called addellstone garage on brighton road its behind the car dealer so not the car dealer but behind it |
22nd Sep 2013 2:28pm |
Ok spoke to Addlestone garage and they gave me the number for a guy called Barry at Thameside Automotive in Shepperton.
24th Sep 2013 4:16pm |
