Home > Technical (L322) > Suspension fault
Jdhall78
United Kingdom 2005 Range Rover Vogue SE Td6 Bonatti Grey
Suspension fault
Hi Was wondering if somone could point me in the right direction?
I have a 2006 TD6 Vogue and last month had the dreaded SUSPENSION FAULT message bong up on the dash.
it cleared very quickly and until yesterday had no issues since.
Now suspension fault then inactive then max speed 30 mph then cooling down.
all these messages popped up at motorway speeds 70mph and didnt affect the car in any way.
all messages cleared within 5 mins and i didnt stop untill i got home.
when i got home i put the car in off road mode and measured the height in each corner
Front Right 850mm
Front Left 850mm
Rear Right 830mm
Rear left 830mm
re checked this morning and found
Front Right 840mm
Front Left 830mm
Rear Right 750mm
Rear left 785mm
Now i am guessing it is not suppose to go down so there must be a leak somewhere.
am i correct in thinking if there is a leak the compressor is working overtime to maintain the car height and eventually overheat?
would make sense as the issue only appears after a long drive.
I am going to try and spray the bags with fairy liquid later today and see if i can spot any leaks but any other advice would be appreciated.
is it ok to drive the car or not at all?
thanks
Joe
Post #211523 22nd Sep 2013 9:59am
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Have you started the car the next morning ?
Not necessarily a leak… mine will lower it self over night
(parked on a unlevelled drive)….then as soon a I put the key in the next morning
Car “level’s” itself free use of "RSW" all comms to anyone nearby
Post #211524 22nd Sep 2013 10:07am
They all settle and if ground in not completely flat car will level so different measurements either side!
Post #211525 22nd Sep 2013 10:09am
Jdhall78
Hi Thanks for the quick reply
last night i started the engine and put it into off road height left the engine running until it was all the way up then switched off and licked the car.
this morning without unlocking just measured at the same points and it hd gone down on its own?
Post #211526 22nd Sep 2013 10:12am
Should not have licked it Laughing
It WILL settle...
Post #211527 22nd Sep 2013 10:15am
Jdhall78
haha just spotted that i knew thats where i went wrong Smile
Post #211528 22nd Sep 2013 10:16am
Jdhall78
so any idea what could be causing the messages?
Post #211529 22nd Sep 2013 10:23am
have a read/search in the tech and maintenance sections for eas and suspension faults, there's loads on this subject .. .. ... - .- -.
Post #211530 22nd Sep 2013 10:27am
If you drop your fattie down to access mode then raise it to off road height does it go up ok? Does it say "raising slowly"?
I had a split airline connector that caused my fault. As said before, it will drop in height overnight so don't use that as a test. Thumbs Up Previously..
Post #211532 22nd Sep 2013 10:33am
^^ should raise smoothly, best to do it after a run, as the compressor will have fully charged the air reservoir. Once you have used all the air up it will go up slowly, so dont expect to repeat access to offroad over and over again without it displaying raising slowly.
Do it once, after a run. Then run it leave it for a bit then try. Result should be the same.
Then put it in off road height and have a listen round the car for leaks, in the boot well also. There is nothing that can't be fixed with a hammer😜😜
Post #211542 22nd Sep 2013 12:00pm
Jdhall78
Ok just went on a 70 mile run no issues until 58 miles then suspension inactive max speed 30mph no lights on height selector.
Car still drives fine pulled over message disappeared and all lights back on selected access mode went straight down then full height mode and back up completely normal?
I did notice the other day whilst cornering slowly the traction control light flicked on abs sensor?
I am going to give the wheel arches a good clean out and make sure the sensors are clean and see how it goes on the way home.
Failing that can anyone recommend a good independent LR mechanic near Chertsey surrey?
Thanks for all your advice so far.
Post #211547 22nd Sep 2013 1:03pm
hoppy
see if you can find someone local to clear your fault codes first... free use of "RSW" all comms to anyone nearby
Post #211558 22nd Sep 2013 3:10pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Yes there is one only 5min from you
Its a really good one
Called addellstone garage on brighton road its behind the car dealer so not the car dealer but behind it
Post #211562 22nd Sep 2013 3:28pm
Jdhall78
Ok spoke to Addlestone garage and they gave me the number for a guy called Barry at Thameside Automotive in Shepperton.
Plugged my Fatty into his diagnostics and it showed loads of old faults but one in particular steering angle sensor.
He reset the codes and told me to have a drive around for the next few days and see if the fault returns.
He spent nearly an hour checking things and seemed very knowledgable and best of all only charged me £30!
Will defiantly be using his garage again!
Will keep you posted over the next few days.
Post #212020 24th Sep 2013 5:16pm
