Home > Maintenance & Mods (L322) > Coolant - how much and what type?
petewild
England 2002 Range Rover HSE 4.4 V8 Java Black
OK, this should hopefully be a simple one for someone on here.
Here's the scenario, at the end of August I finally got fed up with the slow coolant loss that had plagued me for months and decided to change the radiator ( which was showing some staining at one of the seams ), that cured the leak, but my mechanic filled the system with water only, just as a proof that we wernt still losing anything, plus it was summer so no danger of anything freezing.
Soooo now I have a watertight, and full cooling system.
My questions are;
1. Ive read lots about specific antifreeze types and not mixing different types etc, so whats the ideal type to use? Assuming I dont have anything in there at the moment so cant really mix it.
2. How much water should I drain and replace with antifreeze to reach a required water/antifreeze ratio?
Roughly of course.....
Thanks
Post #211504 21st Sep 2013 9:32pm
this might help,
http://www.fullfatrr.com/wiki/Recommended_Lubricants ... - .- -.
Post #211509 21st Sep 2013 10:10pm
steptoe
Re: Coolant - how much and what type?
Regardless of it being summer anti freeze also contains corrosion inhibators.
Not a good idea to run the system with just water for any length of time.
Post #211550 22nd Sep 2013 1:17pm
Suggest you drain it both from the rad and engine block, give a good flush then refill with 50/50. .
Post #211554 22nd Sep 2013 1:48pm
pld118
Is it safe to top up with the same spec and type coolant albeit made by a different manufacturer?
Main dealer where I got this pictured coolant seems a bit far to go:
Local jaguar dealer says they use "Jaguar's own" so wondering whether to buy that or some other branded but equivelant spec coolant from say Halfords or ECP.
Trying to top the system up to see if it will stabilise before returning car to main dealer if problem persists.
Thanks Thumbs Up
Post #266239 19th Jun 2014 2:06pm
Here's the scenario, at the end of August I finally got fed up with the slow coolant loss that had plagued me for months and decided to change the radiator ( which was showing some staining at one of the seams ), that cured the leak, but my mechanic filled the system.............................
I would seriously think about using another mechanic my friend... Thats not good practice at all... At best he should have booked you in to replace your coolant rather than leave you to potentially run around for months without... Rolling Eyes
Post #266336 19th Jun 2014 9:39pm
pld118
Parts Dept at RR main dealer said as long as the coolant is pink, organic and same spec it can be mixed with that of a different manufacturer to the one they use. Better safe than sorry!
Post #266443 20th Jun 2014 3:08pm
pld118
As the RR dealership was too far to justify going to for pink coolant, visited the local Jaguar dealership this afternoon and was assured this pink coolant is suitable for the 4.2 and can be safely added to top up the existing RR dealer supplied coolant.
Difficult to compare them from labelling but all seems logical, particularly following the 'JLR franchise supplied' part!
Post #266472 20th Jun 2014 6:13pm
pld118
Come on chaps.. Tumbleweed on this one.. do we think I'm safe to top up the existing coolant that's in the system with the Jaguar coolant? ... Or not
Plea ease? Wink
Post #266499 20th Jun 2014 10:19pm
Prop
I would do it without worrying. so long as its pink I would mix with other pink stuff. Thumbs Up
Post #266502 20th Jun 2014 10:39pm
pld118
You'll do for me Prop, thank you.
Post #266524 21st Jun 2014 7:06am
pld118
Main dealer has today confirmed that the below Jaguar pink antifreeze coolant is suitable for the L322 4.2 SC and is made of the same ingredients as the Oat 5 that they use.
[/quote]
Post #267466 26th Jun 2014 3:10pm
Prop
Told you it was ok,,,, Rolling with laughter
Post #267468 26th Jun 2014 3:15pm
pld118
And I believed you Prop Thumbs Up
Post #267492 26th Jun 2014 4:52pm
Prop
Phew thank god it was the right stuff. Rolling with laughter Rolling with laughter Thumbs Up
Post #267496 26th Jun 2014 4:58pm
