Home > Maintenance & Mods (L322) > Coolant - how much and what type?
Advanced Factors
Site Sponsor
Antifreeze - Corrosion Inhibitor......
Colour - Does not matter, manufacturers use it to aid spotting the level otherwise it would be clear. Saying that a colour system has developed over the years starting Green, then Blue, then Red and now Orange. The difference in them is the inhibitor system.
Blues and Greens were I.A.T or INORGANIC ADDITIVE TECHNOLOGY (Phosphate, Silicate, Borate) used mostly pre 1990
Red was/is H.O.A.T HYBRID ORGANIC ACID TECHNOLOGY (Phosphate Free) Used from about 2000 good for 5 years / 100,000 miles
Orange is O.A.T �PURE� ORGANIC ACID TECHNOLOGY This technology is good for 5 years / 150,000 miles
Red and Orange have less environmental impact.
You need them year round to prevent engine corrosion as well as in winter to prevent freezing
Typical construction is:
Glycol: 95%
Ethylene Glycol
Propylene Glycol ( low-tox products )
Corrosion Inhibitors: 1 to 4%
Inorganic/ Organic
Water 1 to 3.5%
Antifoam 10 to 1000ppm
Bitterant ~70ppm
Dye Trace
There is also a yellow one made by Prestone which will mix with any colour antifreeze without changing the original colour.
So for RR use Red, Orange or the Prestone product. Paul Redding
+44 (0)23 8052 2760
paul@advancedfactors.co.uk
Post #267621 27th Jun 2014 1:51pm
pld118
Thanks Steve,
I'd done research and actually saw many favourable views and review about Prestone AF/ coolant.
My thoughts were, if not able to use my main dealer supplied coolant and hastily needed to use a different make:
A. Was it the correct spec for the 4.2 SC? ; &
B. Could a different make of coolant be safely mixed with the existing MD supplied coolant?
Due to the distance from my MD, I went for a litre of Jaguar coolant from our local Jaguar dealership (more expensive than the RR supplied coolant, however using the JLR logic bomb). In the event, although I've now used up my MD supplied XLC OAT, I've sourced the coolant discharge to an open bleed screw which I've 'sorted' and so have not actually had to use the Jaguar coolant yet which then gave me time to ask my MD if that spec Jaguar coolant was compatible because obviously I don't want to do anything that might be deemed to invalidate the LR warranty.
As mentioned, the MD has put in writing that the above spec Jaguar coolant is compatible.
Post #267625 27th Jun 2014 2:12pm
Advanced Factors
Site Sponsor
Yes saw the post on it, the important thing is the O.A.T.
The Pink colourant is just a way of implying the OE product has something special in it "A sprinkling of fairy dust" Rolling Eyes
It doesn't need to be Pink and it will mix Paul Redding
+44 (0)23 8052 2760
Post #267627 27th Jun 2014 2:20pm
