Home > Technical (L322) > Shunt
Shunt
has anyone experienced a slight shunt in the driveline of the rr on first moving away in the mornings, feels like a delay in going up a gear albeit for a couple of seconds ====================================
Post #1086 17th Oct 2008 3:44pm
That's been a part of RR since they were first built! Discovery 4 HSE
Post #1644 10th Dec 2008 5:26pm
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
i think so although i reverse out my drive and it is uphill so this would feel different anyway. cold weather could stop the oil warming up and lubricating properly so it might be worth waiting a few more seconds than normal before setting off to see if that helps ?
Post #1648 10th Dec 2008 7:28pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Re: Shunt
Mick glad you used the right term "Shunt" and as RRUK states Thumbs Up
Post #1657 10th Dec 2008 9:26pm
Vogue
If the vehicles been parked on slightly sloping ground and / or not run for a few days this can cause a shunt as the oil has drained down out of the system. It can also be caused by a blocked transmission filter on certain RR models - including the Classic. Shunts can also be caused by wear.
If it only happens when the car /gear box oil is cold then its liklely that its just the oil draining back out of the system.
Post #1658 11th Dec 2008 10:15am
Larry
England 2006 Range Rover SE Td6 Java Black
Sometimes I get a hesitation (slight juddering like cycling back and forth between two gears) changing up between 30 - 40mph when cold and accelorating hard, is this likely to be caused by the same thing? It only happens once and doesn't happen again in that journey.
I had another auto that always changed up very late on the first gear change when cold then was fine after that.
Post #1661 11th Dec 2008 10:37am
