Home > Technical (L322) > Shunt |
has anyone experienced a slight shunt in the driveline of the rr on first moving away in the mornings, feels like a delay in going up a gear albeit for a couple of seconds ====================================
17th Oct 2008 3:44pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
That's been a part of RR since they were first built! Discovery 4 HSE
10th Dec 2008 5:26pm |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 |
Mick glad you used the right term "Shunt" and as RRUK states |
10th Dec 2008 9:26pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
If the vehicles been parked on slightly sloping ground and / or not run for a few days this can cause a shunt as the oil has drained down out of the system. It can also be caused by a blocked transmission filter on certain RR models - including the Classic. Shunts can also be caused by wear.
11th Dec 2008 10:15am |
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 |
Sometimes I get a hesitation (slight juddering like cycling back and forth between two gears) changing up between 30 - 40mph when cold and accelorating hard, is this likely to be caused by the same thing? It only happens once and doesn't happen again in that journey.
11th Dec 2008 10:37am |
