Home > Technical (L322) > "HELP"SHUT DOWN!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
i think there's a software update for the battery problem... ... - .- -.
9th Sep 2013 7:58pm |
stevb Member Since: 29 Jul 2013 Location: scotland Posts: 4 |
Thanks Stan, I will tll the dealers tomorrow when they phone |
9th Sep 2013 8:13pm |
if you search ''battery problem'' there's a few threads relating to the 2010 onwards battery/software problem. ... - .- -.
9th Sep 2013 8:20pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Mine has done exactly the same after a few minutes?
10th Sep 2013 3:22pm |
Dealer didn't telephone me today so still waiting to find out whats happening. ill let you know |
10th Sep 2013 5:57pm |
Dave ray Member Since: 19 Sep 2011 Location: Wirral Posts: 92 |
Mine did it the other day but was saying monitor shut down to overheating sorry to jump your thread |
10th Sep 2013 7:23pm |
wrong thread Dave..this is a 2010 battery problem which is corrected by a dealer software update and a new replacement battery.. ... - .- -.
10th Sep 2013 7:25pm |
Sorry |
10th Sep 2013 8:11pm |
Range Rover LSE Member Since: 15 Jul 2012 Location: Preston Posts: 46 |
Mine is a 2010 and does the same, it follows on from when they updated the software and fitted a new gel battery, the software change also cut down the amount of time that the FBH will run for after switch on. As I recall the software mods were part of a service bulletin, but I'm sorry I cannot remember which one. Range Rover Sport 2023 D350 Autobiography
10th Sep 2013 11:03pm |
Sorry I should have said but I think the software mod was put in to protect the battery and problems people had been having, the result is that it is very protective of anything that is power hungry such as the TV and soon goes to shut it down. Range Rover Sport 2023 D350 Autobiography
10th Sep 2013 11:07pm |
so am i correct in assuming that if the 'shut down' error appears then you must have the software update already.. ... - .- -.
11th Sep 2013 8:33am |
I would assume the software mod is in place, it was all part of the service bulletin which changed the battery to a gel type. I bought my car a little over a year ago from a main dealer, I had no problems with the car, battery was fine etc, however I noted on TopIX that there was this service bulletin outstanding so I advised the dealer and they carried out the job, changing the battery as well as the mod at the same time. Following which the timing for the FBH was reduced and the warning described appears.
11th Sep 2013 10:10am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 |
the software mod is LESS protective of the battery than the factory setting.
12th Sep 2013 5:49pm |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
...see also
13th Sep 2013 9:43am |
