![]() | Home > Maintenance & Mods (L322) > Changing Seat Colour |
Your problem is the Dashboard and trim plastics are green and will not work with any other interior colour seats/carpets etc |
TtheArab Member Since: 26 Apr 2013 Location: Dunblane, Scotland Posts: 89 ![]() ![]() |
Good point. How far do you end up going ???? Given the car only has 60k on the clock though and 2 owners (with me) she might just be worth it.... |
Might be possible to dye them? I know Alan3 a member on here dyed a brown steering wheel black to good effect. Might be worth a try if it doesn't work buy a used set. Present :2008 TDV8 HSE
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3221 ![]() ![]() ![]() |
let's have some pictures to help us make your mind up! |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
In my opinion, the sheer amount you'd have to replace I question if its worthwhile. Also, once trim has been dismantled once or twice I don't think it ever goes back the same and you end up with mystery squeaks and rattles.
All good points and as such I took a look when I had to go out to drop the mutts off for the weekend at our daughters. I actually think based on the mix of what is there now cream/ivory will actually work with existing setup for dash etc.
Mph28mph Member Since: 16 Jun 2013 Location: Wigan Posts: 112 ![]() ![]() ![]() |
Just swap the seats out for ivory with aspen piping (cream with green) that's what I have in mine. |
^ Good plan if you can locate a set |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Ebay item: eBay Item No. 231047734731
Guess you could get then Connelly sprayed Parchment/Ivory but may not be worth it. |
I didn't realise you could get seat envy..... MPH I want those seats........ |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6766 ![]() ![]() ![]() |
Yes indeed I dyed my steering wheel from brown to black, but the problem you would have is that you cant dye leather to a lighter tone than it is, so going from Aspen (dark green?) to say ivory or parchment won't work.
Tthearab
