Home > Technical (L322) > Hunting (Not the wildlife type)
Al Hornby
Morning All.
A quick query if I may, as Im sure someone will know the answer out there.
The engine in my TDV8 has started to hunt and surge when cold. not all the time. You can feel it and see it on the rev counter It does seem to be better if I knock it out of gear and it seems to go away when warm. Ive tried a fuel additive in case it was an injector issue. Has anyone got any thoughtas please.
Many thanks.
Al
Post #207851 4th Sep 2013 7:12am
EGR not closing compleatly?
Post #207862 4th Sep 2013 7:48am
Split in an intake pipe or intercooler, Closes when it warms up Confused Thumbs Up
Post #207863 4th Sep 2013 7:49am
Al Hornby
Many thanks Craig. Is there any way of knowing which is the likely cause. Are there any tests I can do at home to narrow the problem down a bit?
Cheers.
Al
Post #207970 4th Sep 2013 3:04pm
I had a split fuel intake rail (low pressure) with similar symptoms. If its this you will smell the Diesel in the engine bay and see it looking down left side of engine as you look in. Possible fine mist of Diesel as well...
Post #207971 4th Sep 2013 3:13pm
Al Hornby
Cheers Gary.
Al
Post #207980 4th Sep 2013 3:56pm
I guess its the other bank it could be the right side as well! (Mine was the left)
Post #207981 4th Sep 2013 4:00pm
