Home > Maintenance & Mods (L322) > Rear window seal corrosion
Page 2 of 3 <123>
that is indeed the corrosion problem Andy.. ... - .- -.
Post #231491 26th Dec 2013 4:44pm
Van Diesel
United Kingdom 2014 Range Rover Vogue SE SDV8 Mariana Black
Nice one Stanley !! Thumbs Up Thanks
Post #231492 26th Dec 2013 4:48pm
wealy
just had a look at mine and they are the same...
Post #231983 30th Dec 2013 12:26pm
Van Diesel
Update
Phoned local dealer during the Xmas break re the corrosion I had noticed on the seem along bottom of upper tailgate. They sent me to their approved repairer for an inspection.
Relevant photos of blistering on tailgate and rubber window seals taken to be sent to LR.
Phone call today to say all approved by LR and booked in for next week for repairs totalling £1600.
Well pleased with LR Thumbs Up
Post #233491 7th Jan 2014 9:28pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
mine are being replaced under general warranty.
beadles tell me this is only covered for 3 years - the corrosion warranty only applies to the paint they say....
Post #234082 11th Jan 2014 12:17pm
cloudwind
Hi
Main dealer replaced mine with no hesitation while the car was in for 24 month service. Never had rust on a 2 year old car before!!!!
Cheers
Post #234111 11th Jan 2014 4:55pm
simonreed
Hi - I have the same problem but no warranty, does the window mount on-top of the seal and therefore you have to have the window off to replace?
Thanks
Post #391738 15th Jun 2016 10:24am
rear screen stays where it is , the trims just pull off and the new ones slide back on.. ... - .- -.
Post #391739 15th Jun 2016 10:35am
simonreed
thanks
Post #391740 15th Jun 2016 10:39am
johnb8538
United Kingdom 2014 Range Rover Autobiography SDV6 Fuji White
Similar problem
2011 Autobiography in lovely condition let down by these silly strips.
After reading the comments I called the local Leeds dealer who dismissed it right away as a corrosion covered part.
They did however give me the part numbers DED500180 and DED500190 which they will charge you £60 for and £110 to fit. I spoke with the service department who admitted its an easy DIY fit and found a set on fleabay for £45. As I've just bought the car I'm letting the salesman fight my corner with Landrover to see if he can get a free set first but if not then £45 is reasonable as it does look flipping awful.
Post #406157 24th Sep 2016 9:23am
simonreed
I would just take them off and not replace them. Looks better and my old 2008 didn't have them.
Post #406166 24th Sep 2016 11:41am
Yep, as above. Just pull them off an put them in the bin. Earlier cars didn't have them and they serve no purpose other than to rust.... There is nothing that can't be fixed with a hammer😜😜
Post #406167 24th Sep 2016 11:46am
johnb8538
Thanks gents. After looking today I see they do indeed serve no purpose regards insulation. The previous owner attempted to glue the corroded ends down and made them look worse so it will take some cleaning once I work them off.
Cheers.
Post #406240 24th Sep 2016 10:51pm
TomCobbly
I got mine here...http://www.ebay.co.uk/itm/201649316136?_tr...EBIDX%3AIT
They have sticky pads at either end and when you pull the old ones off it leaves the bottom one behind
Hope this helps
Post #406310 25th Sep 2016 11:58am
johnb8538
Yep, that's the same listing I found.
I'll see what they look like off before I decide.
My last RRS had similar corroded wheel arch fittings which instead of replacing I just left off and the car looked no different. Money was better spent elsewhere.
Post #406335 25th Sep 2016 3:22pm
Page 2 of 3 <123>
