Home > Technical (L322) > Misfire on a on my SC |
Have you tested the MAP sensor or replaced it? It could be failing slowly for example. MY 2010 5.0 SC Galway green and sand interior!!
29th Aug 2013 9:48pm |
Tallsaj Member Since: 23 Aug 2013 Location: Birmingham Posts: 75 |
Hw do I test the map sensor. Will this cause the problem u think? |
29th Aug 2013 10:08pm |
If you go to the below link you will find the workshop manual that covers the "early" SC models. You will find a lot of details on the MAP sensor (since that is the fault coming up) and how to test it.
30th Aug 2013 7:45am |
Thanks Mate that's why it's probably using more fuel also. I can't see the link for the Download? |
30th Aug 2013 9:17am |
If you go to the original post from Joe (the first), copy the http........ and drop it in your browser, that is the download location. MY 2010 5.0 SC Galway green and sand interior!!
30th Aug 2013 9:37am |
K I have downloaded the manual I can't seem to find the search button can u help on this? |
30th Aug 2013 4:42pm |
It's a normal PDF document (at least my version) so you have to go through it manually apart from the hyperlinked chapters. The MAP is somewhere in the engine management section. MY 2010 5.0 SC Galway green and sand interior!!
30th Aug 2013 4:45pm |
chapter 303-14a is the one I think. MY 2010 5.0 SC Galway green and sand interior!!
30th Aug 2013 4:51pm |
