Home > Off Topic - Other Cars > Jag X Type Diesel - Black Smoke |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7802 |
My father has a 2006 2.0D Jag X type, and happened to ask me if its normal to kick out black smoke when you acceleate. I said the usual " a bit if you really floor it and its not been driven hard for some tiome, but only once and then OK".
25th Aug 2013 6:15pm |
Air Filter and general service first, then chuck a small amount of BioD into 1/2 a tank to flush the system out.
25th Aug 2013 6:59pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Gut feeling says it probably needs a good hard run, high revs to get some heat into the exhaust, has it got a dpf? If so they need heating up occasionally to free them of crud this can be achieved by a good long run 1/2 hr plus at high revs
25th Aug 2013 7:44pm |
Blocked EGR valve and manifolds |
25th Aug 2013 9:32pm |
Mark.abersoch Member Since: 23 May 2013 Location: Wirral Posts: 148 |
I'd go with the DPF aswel.
25th Aug 2013 9:44pm |
Or if it is dpf it's better to get someone with local jag/lr diags to force a regen instead. Should only cost a few quid. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
25th Aug 2013 10:06pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
If its an 06 then it won't have DPF... But it has got the 2.0d Mondeo engine that suffered with injector issues
26th Aug 2013 8:47am |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Try this - it may help ?
26th Aug 2013 9:00am |
glennhoward Member Since: 26 Nov 2012 Location: kent Posts: 58 |
Have you tried running your hand down the pipe that comes out the rear of the turbo, these suffer with tiny hairline cracks and this will leave you with plumes of black smoke covering the road under acceleration. I tried all the EGR methods before I found this problem, turned out to be quite a common failure on all the mondeo diesels. Hope this helps. |
27th Aug 2013 9:22am |
Many thanks for all your replies.
27th Aug 2013 5:35pm |
gvw Member Since: 30 Apr 2012 Location: South Yorkshire Posts: 10 |
I'll go with Glenn. I had a similar problem on a mondeo and couldn't see the split in the pipe until I had removed it |
27th Aug 2013 6:12pm |
Bit of an update, he's given it a bit of a thrashing and it no longer emits black smoke. To be honest it only gets really short runs and he tries to drive economically and not rev it.
21st Sep 2013 5:20am |
👍 thats good. And cheap.
22nd Sep 2013 10:41am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I remember Basil Fawlty thrashing a car. What kind of a tree do you use to thrash a modern diesel? |
22nd Sep 2013 6:45pm |
