Home > Off Topic - Other Cars > Jag X Type Diesel - Black Smoke
mjdronfield
My father has a 2006 2.0D Jag X type, and happened to ask me if its normal to kick out black smoke when you acceleate. I said the usual " a bit if you really floor it and its not been driven hard for some tiome, but only once and then OK".
He's had the car about 4 years now, its done about 35k miles. I followed him yesterday, and boy is it not normal. He floored it in 2nd and I couldn't see his car for black smoke, and then none of the oncoming traffic either. It also put smoke out on any slight incline, without the throttle hard down. All the time.
He said its been doing it for a couple of months. He's had the EGR replaced last year at a Jag dealership, so I can't imagine its that.
I'm hoping its not gonna be too expensive, as my step mum will have him sleeping outside through the winter.
I've suggested he check the air filter and intercooler pipes.
He says it drives fine, no lack of power, no unevenness or lumpy idle etc.
Last year, I seem to remember he said he had the glow plug warning light come on whilst he was driving, and the car lost all power. He pulled over, turned the ignition off and on, and it was fine again. Did it 3 or 4 times over a period of about 4 or 5 weeks, then has been fine since. At the time, a search of the web seemed to indicate "low fuel pressure". We put it down to a "glitch".
He has no warning lights on of any sort now.
Hoping its not injector related ?
Have you folks got any further thoughts or ideas ?
Have searched the web, to see most people end up at EGR........
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #205690 25th Aug 2013 7:15pm
Air Filter and general service first, then chuck a small amount of BioD into 1/2 a tank to flush the system out.
Another thing i do sometimes but on older diesels is park the car pointing downhill for the night and then squirt some fairy up the exhaust and then fill it with water untill it starts to trickle out. This then will loosen any crud built up inside the silencers. In the morning start the car and dont rev it at all for about 30seconds and it will just flush the water and crud out. Drive the car normally and it should help.
If its such low miles my gut feeling will say the injectors are not spraying correctly due to not having long runs to get them red hot and clean off. Cleaning them may be the best bet but i think that engine is a lot of fun to get the injectors out.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #205696 25th Aug 2013 7:59pm
My FFRR did something similar and it turned out to be a split hose.
Belched out black smoke, then a few times got a 'Special Programs Off' message before being consigned to limp mode. Quick switch off & back on and all seemed fine (except for the black smoke).
I was very relieved that it only cost me about £30 - I hope it's something similar.
Post #205698 25th Aug 2013 8:14pm
Gut feeling says it probably needs a good hard run, high revs to get some heat into the exhaust, has it got a dpf? If so they need heating up occasionally to free them of crud this can be achieved by a good long run 1/2 hr plus at high revs
If its been running fine then i would hesitate to suggest injectors, however if its not cruddy then it is possibly overfuelling somehow and the first point of call is to plug it in and see if there are any fault codes. There is nothing that can't be fixed with a hammer😜😜
Post #205702 25th Aug 2013 8:44pm
Blocked EGR valve and manifolds
Post #205730 25th Aug 2013 10:32pm
Mark.abersoch
United Kingdom 2010 Range Rover Vogue SE TDV8 Bonatti Grey
I'd go with the DPF aswel.
Needs a good run at a constant speed on the motorway so it should regenerate. I'm sure it's sitting in 4th if its 5 speed or 5th if its 6 speed doing about 2500 revs for 20 mins once warm!
The DPF will be getting blocked a its hardly done any mileage a good run will do it the world of good every now n then.
Thanks 2009 TDV8 Vogue SE - Bonatti Grey
Post #205731 25th Aug 2013 10:44pm
Or if it is dpf it's better to get someone with local jag/lr diags to force a regen instead. Should only cost a few quid. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #205735 25th Aug 2013 11:06pm
If its an 06 then it won't have DPF... But it has got the 2.0d Mondeo engine that suffered with injector issues Whistle
Ide start with a track day session drive for an hour and clean it all out Thumbs Up
Post #205759 26th Aug 2013 9:47am
TugRR
Try this - it may help ?
http://www.honestjohn.co.uk/carbycar/jagua...ection=bad
Thumbs Up Where do you go after one of these . . . ?
Post #205762 26th Aug 2013 10:00am
glennhoward
United Kingdom 2003 Range Rover Vogue 4.4 V8 Epsom Green
Have you tried running your hand down the pipe that comes out the rear of the turbo, these suffer with tiny hairline cracks and this will leave you with plumes of black smoke covering the road under acceleration. I tried all the EGR methods before I found this problem, turned out to be quite a common failure on all the mondeo diesels. Hope this helps.
Post #205890 27th Aug 2013 10:22am
mjdronfield
Many thanks for all your replies.
Probably won't see the car myself until the weekend to check for things myself. I'll give him the feedback over the phone so he can have a look himself first.
Thanks again. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #205974 27th Aug 2013 6:35pm
gvw
I'll go with Glenn.
I had a similar problem on a mondeo and couldn't see the split in the pipe until I had removed it
Post #205981 27th Aug 2013 7:12pm
mjdronfield
Bit of an update, he's given it a bit of a thrashing and it no longer emits black smoke. To be honest it only gets really short runs and he tries to drive economically and not rev it.
He has bought a bottle of forte advanced diesel treatment and will give it a workout every so often to clear things out.
Thanks for your help. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #211409 21st Sep 2013 6:20am
👍 thats good. And cheap.
Have had that a few times on various diesel cars, a good thrashing basil fawlty style will usually sort it.
Swmbos skoda threw an engine management fault a week or so back. Damn good thrashing(car not swmbo) sorted that too and that is a petrol.... There is nothing that can't be fixed with a hammer😜😜
Post #211539 22nd Sep 2013 11:41am
RR2008HSE
I remember Basil Fawlty thrashing a car. What kind of a tree do you use to thrash a modern diesel? Mr. Green
Post #211579 22nd Sep 2013 7:45pm
