Home > Maintenance & Mods (L322) > How to disable seatbelt warning on 2010MY?
The old trick of clicking the seatbelt in and out ten times in 30 seconds doesn't seem to work on my dad's 2010MY car, is there a new way of doing this?
thanks Discovery 4 HSE
Post #200994 26th Jul 2013 3:17pm
essexfarmer
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
I disabled the warning on our 12MY, if I remember correctly, you switch on the ignition without starting the car and then plug/unplug the seatbelt 9 times, you should the hear a 'bong' and it should be disabled. 12MY Black FF VSE
12MY Orkney Grey HSE Lux RRS
Post #200996 26th Jul 2013 3:29pm
Vogue
As above, Did mine, think the ignition was on, nobody sat in seat and connected and disconnected seat belt till you got the bong - might have been 9 or 10 times 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #201005 26th Jul 2013 4:24pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
I struggled to get this to work on my 2010MY, in the end I used my faultmate Whistle
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #201137 27th Jul 2013 3:41pm
I tried the 10 times trick the other day but because the car was boxed in I couldn't take it for a spin to see if it had worked, had a message from my Dad saying it HAS worked so thanks chaps for the confirmation, I shall need to do this on my Supercharged when I get it too. Discovery 4 HSE
Post #201253 28th Jul 2013 12:51pm
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
I will give his a try later today on my 2012..... how annoying can a constant bong be if oyu only drive along on your own premises..... Thumbs Up
regards
heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #322583 14th Apr 2015 2:15pm
heppsen
Worked! Thumbs Up
Regards
Heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #322604 14th Apr 2015 6:09pm
Why would anyone want it turned off? Its law to wear then and foolish not to surely! Whistle Whistle Whistle
Post #322618 14th Apr 2015 6:50pm
I always wear mind on the road but there's times on shoots, farms, fields etc and you don't need it, a bong is just annoying. Discovery 4 HSE
Post #322624 14th Apr 2015 7:12pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I'm seatbelt exempt through surgery forever now so I got a td5 steel clip and just leave it plugged in all the time, annoying it is tbh the old 03 was fine. _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #322726 15th Apr 2015 3:24pm
n1cktdv8
The 10 times click didn't work on my 2007 Is this where I put the car details and a bit about myself ?........
Post #322729 15th Apr 2015 3:46pm
should do Nick, try nine... ... - .- -.
Post #322730 15th Apr 2015 4:22pm
Emperor Mong
It worked on my old MY11 and it even worked on my MY14 L405.
Post #322735 15th Apr 2015 5:51pm
n1cktdv8
Car running or just ignition on ? Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #322739 15th Apr 2015 6:07pm
Vogue
Ignition on only - make sure no weight on the seat cushion and connect and disconnect the seat belt - sure mine made a bong when deactivation was complete 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #322740 15th Apr 2015 6:16pm
