Home > Technical (L322) > Air Conditioning Service with LPG installed? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
I'll put a £10 bet on the hevac playing up |
28th Aug 2013 8:38pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 |
so today my IIDTool arrived and I went outside to play with it
30th Aug 2013 2:38pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Supprised the 'experts' didnt find that - glad you narrowed it down |
30th Aug 2013 7:02pm |
It could be a connector or wiring indeed, worth a check. Also you can take the connector of and see if the coupling can be activated externally by putting 12V on it directly.
31st Aug 2013 6:17am |
cheers for that
31st Aug 2013 10:24am |
Nope, now you just need to find a good Indy that can do the work for you or get your hands dirty. No clue what the clutches go for but Dan can probably give you a quick price And I bet Craig will do a great job as well if he is not to far from you MY 2010 5.0 SC Galway green and sand interior!!
31st Aug 2013 1:40pm |
this linky has been posted before so that's a compressor for £310.58 unless anyone knows anywhere cheaper? or there's a reason not to use this source or product?
31st Aug 2013 5:24pm |
1st Sep 2013 4:45pm |
