![]() | Home > Technical (L322) > Air Conditioning Service with LPG installed? |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
no I dont. would it be useful in diagnosing what the feck is going on with my air con? |
well I did go to people who are regarded as specialists but the access issue from the lpg plumbing left them as bad as a franchise teapot. As I said it's in for a couple of proper services over the next week and I'll keep updating as we go
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
BT IIDTool not released for general sale yet - maybe a general OBD reader will give you the evaporator temp but I doubt it. |
the saga continues..... still no air con
Its pretty easy to tell if the compressor is running - you will hear the clutch engage and dis-engage when you turn the system on/off and mine kicks on/off under normal running. |
I'll have another butchers tomorrow.
I had a couple of hours going thru RAVE yesterday so I'm in more informed position.
Soggy - do you have TOPIX? Its much more relevant to your MY |
thought that was trade only? anyway I have this http://www.fullfatrr.com/forum/topic17623.html which appears to definately be for my 2007MY . |
Yes that contains the data from Topix |
still not fixed. access to LP port sorted, no sign of pressure loss or leakage; but still no cold.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 754 ![]() ![]() |
Did you confirm that the LPG hot water routing was correct ?
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
I had the same problem when I converted my SC to LPG . I had inadvertently plumbed in the water to return in to the wrong hose. This bypassed one of the water valves and allowed hot air to be blown through the right hand face vent and cold air to the left.
sorry Cass, I should have said - this is a new issue.
