Home > General > Very Heavy Stearing at slow speeds
geoff1
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Hi For the last couple of months the steering on my ffrr almost un turnable at slow speeds. Anyone got any suggestions.
Thanks
Geoff
Post #16138 4th Apr 2010 3:16pm
Have you checked the PAS fluid level? If it's low it will struggle. If it's low, look for leaks, the engine undertray often hides leaks by catching drips.
If level is fine, there may be a blockage or something more sinister? Anyone? Discovery 4 HSE
Post #16140 4th Apr 2010 3:35pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Also tyre pressures can make a big difference.
Post #16145 4th Apr 2010 4:46pm
Good point, also, I presume the PAS is belt driven from the engine so maybe the belt is slipping/worn?
Can anyone confirm?
I'll check the Workshop manual and see what it says. Discovery 4 HSE
Post #16189 5th Apr 2010 3:20pm
KING OF THE ROAD
Could be this......
I recently had my FFRR serviced a while back by a specialist who noticed that the power steering had a leak from the steering rack input shaft seal and mentioned that there should be no problem with the dealers identifying or correcting this under warranty.
I never got round to taking it into the dealers, however over the over the last couple of months the steering was getting harder generally whenever you turn the steering wheel. Eventually, I had the steering rack replaced last week under warranty at Lookers - Park Royal - London (fullfatrr.com site sponsors) and it has made a very big difference - silky smooth!!
Post #16227 6th Apr 2010 2:55pm
