![]() | Home > General > Very Heavy Stearing at slow speeds |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Have you checked the PAS fluid level? If it's low it will struggle. If it's low, look for leaks, the engine undertray often hides leaks by catching drips.
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Also tyre pressures can make a big difference. |
Good point, also, I presume the PAS is belt driven from the engine so maybe the belt is slipping/worn?
KING OF THE ROAD Member Since: 06 Jan 2009 Location: UK Posts: 34 ![]() ![]() |
Could be this......
