Home > Duckworth Parts > Spare wheel lifting strap / Pollen filter |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
Hi Paul
2nd Jul 2013 4:11pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Dan - PM sent
2nd Jul 2013 6:51pm |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 |
What's a spare wheel lift strap/cradle? 4.4 TDV8 Vogue Baltic Blue MY11 |
2nd Jul 2013 11:18pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35312 |
its a couple of straps with a rubber type handle ...the straps go underneath the wheel/tyre and you use the handle to pull up and out the wheel/tyre.. ... - .- -.
3rd Jul 2013 8:27am |
. . . . clever bit of kit, but for some reason not fitted to all cars
3rd Jul 2013 8:34am |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
If you use it correctly, the handle slots into the lock in the centre of the lower tailgate (when it's in the up positions) and then you just open the lower tailgate and the spare wheel is pulled into a position where you can slide it onto the lower tailgate.
3rd Jul 2013 11:59pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16286 |
Factory fitted till 2005 facelift... Then Ford junked it... One of the best bits of the early cars when you have a back like mine! |
4th Jul 2013 5:55am |
I had it in my last one which was an A6 chassis number . Took it out and fitted it to my new one, just make sure you get the plastic strut to pop in the locks and hold the lower tail gate open . 2008 MY Supercharged
4th Jul 2013 7:02am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
Out of idle curiosity, is this something that can be retrofitted to later models?
4th Jul 2013 7:03am |
I had it in my last one which was an A6****** chassis number . Kept it for my next one , make sure you get the plastic strut to hold the tail gate open . 2008 MY Supercharged
4th Jul 2013 7:05am |
Trev18 Member Since: 23 Apr 2013 Location: North Manchester UK Posts: 267 |
Just checked... Got the strapping in my FF, but no plastic strut to hold the tailgate down
4th Jul 2013 7:28am |
EPX000030 £3+VAT You can paypal direct using - www.paypal.me/duckworthparts
4th Jul 2013 3:53pm |
Thanks again Dan..
4th Jul 2013 8:08pm |
all received Trev You can paypal direct using - www.paypal.me/duckworthparts
5th Jul 2013 7:19am |
