![]() | Home > General (L405) > Day in an L405 TDV6 Vogue SE |
Arenaitch Member Since: 27 Aug 2012 Location: Twixt Scummers and Skates Posts: 69 ![]() ![]() ![]() |
Considering that the combined mpg figure for the L322 is, I think, in the region of 30mpg, the OBC says ~28mpg over 13k miles but real life at-the-pump measurement is, well, see the Fuelly figure below (best I've ever got was 27.1mpg on my first tankful), I reckon, given the tightness of your new engine then a figure closer to 30mpg could be expected. But a measured (not OBC'd) 37mpg? Not a chance! 2012 FFRR Westminster Orkney / Ivory and absolutely no pimp-glass! ![]() |
Dickie Member Since: 14 Nov 2012 Location: Gloucestershire Posts: 71 ![]() ![]() |
I'm generally getting between 32-33mpg and 3500 miles in. Maybe engine will loosen up more but don't think I'll see north of 35mpg even on a long cruise. |
fairwx Member Since: 10 Nov 2011 Location: bristol Posts: 124 ![]() ![]() |
I have the TDV6 and average 31/32 - its started out very promising but has simply dropped off.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Fairwx,
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Since a L405 is a long way off for me, my preference would be the Supercharged. There's claims of 740+bhp from that engine. In a 2200kg car that's going to embarrass most sports cars and even scare a few super cars. Also you won't look like a twonk like you would in a Bowler EXR. |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
200% agreed ! However, if they'd offer ot on V6, they'd certainly sell less V8... If you do drive both engines for a few hours/days back to back, you WILL choose the V8. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
Absolutely ! ![]() Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
RRUK - I've still got the 4.4 L322 so I did a little comparison yesterday.
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
But that's the point of the thread, RRUK did drive both for a few hours/days.
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
Yes, the V6 rolls around more on the road. Noticably. Compared to the V8 it's quite barge like. The one I tested nose dived badly under braking too. That and the screen put me off a bit to be honest, it's not as good as it could be. They've compromised the V6 to make sure the V8 is worth thousands more. |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2615 ![]() ![]() |
Interestingly, there seems to be a consensus amongst the motoring journalists that the TDV6 is the nicer car to drive - Mike Cross (Chief Engineer at JLR) agrees. |
What I don't understand is why they put the 3.0TDV6 in the L405 yet are putting the 3.0 SDV6 in the Sport.
Presumably getting too close to the V8 - interesting to see what the SDV8 in the Sport makes given that the current 4.4 trails the Germans. |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
Both the V6 and V8 L405 Vogue SE's have Adaptive Dynamics as standard, the V8 also has Dynamic Response which is what improves the ride. |
