![]() | Home > Maintenance & Mods (L322) > Fault code reader |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
I have started getting the "suspension fault - normal height only" messages and the orange suspension height control knob lights turn off. Has anyone used one of the cheap fault code readers which claim to work with any car (this one for £20 seemed very reasonable! http://www.ebay.co.uk/itm/Any-Car-Engine-F...0888167451 )?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35613 ![]() ![]() |
afaik the cheapo ones only read the common generic codes and not the landrover specific ones.. ... - .- -.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
The cheap ones only read the bear minimum "public" OBD2 codes, they are totally useless for anything to do with a vehicle or manufacturer specific system. |
Thanks Stan & Martin I suspected that this might be the case |
only someone with a cheapo reader could answer that Nigel...more money but you could consider a IIDTool or RSW allcoms, these units read and clear vehicle specific codes and the IIDTool lets you configure things like the ranges height and beep on lock etc.. ... - .- -.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
I bought the very same item for my sons fiesta... Worked a treat. Tried it on a diesel mondeo as well, superb... Tried it on the FFRR.... Does not talk to it AT ALL... It just does not communicate. |
Oh b*gger - it's going to the dealer then - I can't justify £300 to check fault codes using the other tools (I'm sure that they are great, but I have no need for the adjustments that they offer). Thanks for the replies! |
Argos sell an RAC one.... You could try it and take it back if it did not work.. |
Ok - I've given in after 25 pages of positive comments on the IID tool and ordered one! |
you wont regret it .. |
Update: very impressed with the support (thanks Patrick) from gap-diagnostics and the unit - loads of fault codes now identified and cleared - although the dreaded "C1A20 Pressure increases too slow when filling reservoir" now needs either a pipe leak identifying or a compressor refurb (or both)! |
I stripped down the compressor - although it seems that it is a newer model with a steel bore (compared to the photos on the wiki); cleaned that up with fine emery paper; cleaned the piston seal and lower seal; lubricated it all with silicone spray.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Where is the best place to get an IID reader? |
