Home > Maintenance & Mods (L322) > Fault code reader
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Fault code reader
I have started getting the "suspension fault - normal height only" messages and the orange suspension height control knob lights turn off. Has anyone used one of the cheap fault code readers which claim to work with any car (this one for �20 seemed very reasonable! http://www.ebay.co.uk/itm/Any-Car-Engine-F...0888167451 )?
I really just want to be able to see what the error codes are before stripping down the compressor etc - rather than playing with settings on the car...
Post #196633 28th Jun 2013 4:40pm
afaik the cheapo ones only read the common generic codes and not the landrover specific ones.. ... - .- -.
Post #196639 28th Jun 2013 4:56pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Had the same issue on mine and it was one of the height sensors. Easily spotted as it was hanging loose. The new one is plastic and not metal , presumably to prevent further failures due to corrosion. Worth a quick look with the old Mark 1 Eye ball Wink
Post #196644 28th Jun 2013 5:14pm
Martin
Site Admin
The cheap ones only read the bear minimum "public" OBD2 codes, they are totally useless for anything to do with a vehicle or manufacturer specific system.
Post #196646 28th Jun 2013 5:24pm
VaguelyVogue
Thanks Stan & Martin I suspected that this might be the case Sad
Do you think that they might be able to read the codes but possibly not have the interpretation of the code (so I could still have more information about faults, but possibly not the translation of the code?
I've had a quick visual check and the height sensors all appear to be there.
Post #196648 28th Jun 2013 5:33pm
only someone with a cheapo reader could answer that Nigel...more money but you could consider a IIDTool or RSW allcoms, these units read and clear vehicle specific codes and the IIDTool lets you configure things like the ranges height and beep on lock etc.. ... - .- -.
Post #196651 28th Jun 2013 5:49pm
I bought the very same item for my sons fiesta... Worked a treat. Tried it on a diesel mondeo as well, superb... Tried it on the FFRR.... Does not talk to it AT ALL... It just does not communicate. Thumbs Up Previously..
Post #196659 28th Jun 2013 6:14pm
VaguelyVogue
Oh b*gger - it's going to the dealer then - I can't justify �300 to check fault codes using the other tools (I'm sure that they are great, but I have no need for the adjustments that they offer). Thanks for the replies!
Post #196661 28th Jun 2013 6:37pm
Argos sell an RAC one.... You could try it and take it back if it did not work.. Whistle
Edit... Think it might be discontinued now.. Previously..
Post #196663 28th Jun 2013 6:40pm
VaguelyVogue
Ok - I've given in after 25 pages of positive comments on the IID tool and ordered one! Thumbs Up
Post #196734 28th Jun 2013 10:58pm
you wont regret it .. Thumbs Up ... - .- -.
Post #196764 29th Jun 2013 8:26am
VaguelyVogue
Update: very impressed with the support (thanks Patrick) from gap-diagnostics and the unit - loads of fault codes now identified and cleared - although the dreaded "C1A20 Pressure increases too slow when filling reservoir" now needs either a pipe leak identifying or a compressor refurb (or both)!
Post #197450 3rd Jul 2013 7:24pm
Post #197453 3rd Jul 2013 7:35pm
VaguelyVogue
I stripped down the compressor - although it seems that it is a newer model with a steel bore (compared to the photos on the wiki); cleaned that up with fine emery paper; cleaned the piston seal and lower seal; lubricated it all with silicone spray.
The problem (I think) was a very wet dryer, so the dessicant was dried out in the oven and repacked. All put back together and no more error messages for the moment.
On off road height, I don't get a corner settling BUT every time I leave the car (in any height), there is air hissing from somewhere near the rear wheels for about 30s - but no further fault codes, so I have two questions:
1) Could this be a leaking pipe between the compressor and valve block?
2) Should I empty the reservoir and drain it in case there is further water in there (I wanted to ensure that the compressor was happy before I did this)?
Post #197619 4th Jul 2013 9:28pm
wealy
Where is the best place to get an IID reader?
Post #202821 7th Aug 2013 3:17pm
