Home > Technical (L322) > Paddle Shift?
Page 3 of 7 <1234567>
Thats Odd I am sure that was the case as he made a point about it when demonstrating the 2011 4.4 I was driving. Perhaps my brain is frying but will check.... Confused
Post #48063 29th Jan 2011 10:13am
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
jsb, have you had a look at the back of the switches attached to the airbag?
Well, behind the telephone/voice/heated wheel set up switches is an unused plug socket
the arrow points to an unused 4-pin receptacle that may well be where the paddles plug in. I only have a pic of the paddles at the moment, but they seem to plug in somewhere in this area.
Wanna have a look and let us know?
taking the airbag off is as easy as
switch off car
open bonnet
open windows just in case
close doors
wait 10 minutes
disconnect neg battery terminal
wait 10 minutes (for any residual charge to dissipate)
remove airbag by pushing a 3mm allen key into the small hole on each side of the plastic surround
voila
(do this at your own risk - no responsibility taken - etc.)
Post #48085 29th Jan 2011 1:45pm
Jsb
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Arrrggghh. Swapped the wheel today, was onlyn10 min job. Will pull it apart tomorrow and take some pics of the connections.
Post #48131 29th Jan 2011 7:31pm
Baben
been holding me breath for ages.....
jsb, did you get round to it?
Post #48906 5th Feb 2011 6:11am
Jsb
Tomorrow, I have been buried this week and removing kitchen tiles today.
Post #49025 5th Feb 2011 8:36pm
Jsb
Ok just done it and can't see any spare plug you mention. Will upload some photos tomorrow.
Post #49028 5th Feb 2011 8:49pm
Baben
Censored . Sorry to hear that. Do you suppose there are such differences in spec? Do you have the heated wheel, telephone and voice controls?
Post #49040 5th Feb 2011 9:13pm
Baben
well I got the paddles (thanks Nick Thumbs Up ) but the receptacle is 4-pin male, and the plug at the end of the paddle loom is also 4-pin male......
methinks there may be a jumper cable required? too scared to plug it in....
any ideas?
Post #59272 7th Apr 2011 3:41pm
pretlove
any ideas?
what did they charge for the paddles? "RANGEISM WILL NOT BE TOLERATED"
Post #59338 7th Apr 2011 9:47pm
Baben
something like GBP40
any help with the fitment?
Post #59403 8th Apr 2011 1:37pm
pretlove
I AM VERY INTRESTED IN DOING THIS AS WELL IM JUST STRUGGLING TO GET MY HEAD ROUND THE ELECTRICS "RANGEISM WILL NOT BE TOLERATED"
Post #59417 8th Apr 2011 3:04pm
Baben
I was hoping that on the 2010/11 it would be plug and play. not sure what you may need for the 2003 - we would need some help from BBSPY or Wiggs
Post #59419 8th Apr 2011 3:06pm
BBS SPY
Cyprus 2003 Range Rover HSE 4.4 V8 Java Black
You rang Whistle
2010 on, it should indeed be a plug and play retrofit situation and will work as long as its enabled in the CCF which is something you have been able to do with the MSV-2 for over a year now Wink
So you follow the connectivity, each paddle switch unit has 3 wires, Ground, illumination (dimmable via the switch module CPU) and the paddle switch signal which goes to ground whenever the paddle switch is held on.
The connection to the switch pack containing the CPU therefore has four connections, Ground and illumination and the switch inputs for left and right paddles.
These paddle switch inputs, along with inputs from every other switch on both steering wheel modules is translated by the CPU into CAN BUS data which is provided to all vehicle systems via the CAN BUS connection of the clock spring.
Although 05 on FFRR vehicles did have a CAN BUS, sadly the steering wheel controls were still using the old BMW IBUS of earlier L322's, which simply does not support Paddles.
It is however not entirely a lost cause, as we believe that we may be able to eventually provide a workable solution Thumbs Up 2003 4.4 HSE
Post #59684 10th Apr 2011 6:26pm
daveo
hi colin, would this be the same unit that will let you use the 2010 steering wheel switches.. V8 facelift Range Rover Autobiography 22" wheels.
Post #59698 10th Apr 2011 7:36pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
that would be very useful indeed!!
matt
Post #59701 10th Apr 2011 7:41pm
