![]() | Home > Technical (L322) > Denso Sat Nav System - Route Calculation |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
AFAIK it does not take live traffic into account in either the planning or live phases.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
shortest is more in time as it takes you down 30/40mph roads .. ... - .- -.
It could take some TMC info into account if you were paid up with Traffic Master but i think after the 1s year no-one ever bothers do they |
TMC is free and uses the FM-RDS signals....normally the TMC gives you an option if there's problems on your route.. ... - .- -.
^+! TMC is built in and free. |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
So will TMC give you the option to recalculate a route if the traffic is bad on a 2007-onwards model?
pretty sure it does , but i never used it ...
Never realised there was more than one standard...
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 ![]() ![]() ![]() |
Does the TMC module use the same FM aerial as the radio? My TMC shows a fault, antenna connection failure, yet my radio works just fine. Should've been old enough to know better...doh! Current 2010 5.0 SC Autobiography Previous 2006 TD6 Vogue SE Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10) |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Yea it does .... had it pop up once or twice on me when there was an accident and subsequent lane closure on motorway .... also shows heavy traffic and road closures when not using sat nav to route anywhere too. |
I keep gettind this on IIDTool but it still works, occasionally requires re-tuning tho |
the TMC should automatically tune to CLASSIC FM or you can manually tune it in the menu.. ... - .- -.
