Home > Technical (L322) > Denso Sat Nav System - Route Calculation
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Planned a route earlier for a trip I will be doing in August to Cornwall and as usual the system calculates 3 routes - 'Shortest' 'Quickest' and 'Normal' if I remember correctly.
200 ish mile journey for 'Quickest' and about 215 ish miles for 'Normal' however 'Quickest' calculated at about 4hrs whereas 'Shortest' was over 6hrs!
Extra 2 hours for 15 miles?
When it works out the route does it take into account traffic issues?
Post #194799 18th Jun 2013 12:41am
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
AFAIK it does not take live traffic into account in either the planning or live phases.
It computes based on road segment speed, distance and preferences.
So for shortist route the calculation is it is distance only.
Quickest is based on distance and road segment speed.
Normal is a mix taking into account your chosen preferences.
Post #194807 18th Jun 2013 5:38am
shortest is more in time as it takes you down 30/40mph roads .. ... - .- -.
Post #194818 18th Jun 2013 7:35am
It could take some TMC info into account if you were paid up with Traffic Master but i think after the 1s year no-one ever bothers do they Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #194831 18th Jun 2013 8:17am
TMC is free and uses the FM-RDS signals....normally the TMC gives you an option if there's problems on your route.. ... - .- -.
Post #194833 18th Jun 2013 8:24am
^+! TMC is built in and free.
Post #194835 18th Jun 2013 8:26am
So will TMC give you the option to recalculate a route if the traffic is bad on a 2007-onwards model?
I know it does that on the latest Freelanders (bit hit and miss, though, in my experience) but didn't think it worked on the slightly older models? Si. <This is my name.
Post #194837 18th Jun 2013 8:29am
pretty sure it does , but i never used it ...
it'll tell you here,
http://www.fullfatrr.com/gallery/albums/us...ration.pdf ... - .- -.
Post #194839 18th Jun 2013 8:31am
Never realised there was more than one standard...
http://en.wikipedia.org/wiki/Traffic_messa...ed_Kingdom
Guess I'm getting confused with the one fitted in My C5 tha screams at me its out of subs every now and again! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #194841 18th Jun 2013 8:49am
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
Does the TMC module use the same FM aerial as the radio? My TMC shows a fault, antenna connection failure, yet my radio works just fine. Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #194842 18th Jun 2013 8:50am
Katash
Yea it does .... had it pop up once or twice on me when there was an accident and subsequent lane closure on motorway .... also shows heavy traffic and road closures when not using sat nav to route anywhere too.
Post #194844 18th Jun 2013 8:52am
Katash
I keep gettind this on IIDTool but it still works, occasionally requires re-tuning tho
Post #194845 18th Jun 2013 8:54am
B9er
Same here, its the IIDTool that shows the fault. How do you retune the TMC? Should've been old enough to know better...doh!
Post #194865 18th Jun 2013 10:32am
the TMC should automatically tune to CLASSIC FM or you can manually tune it in the menu.. ... - .- -.
Post #194871 18th Jun 2013 10:47am
B9er
That did the trick, thank you Stan for the advice, much appreciated. Should've been old enough to know better...doh!
Post #194883 18th Jun 2013 11:57am
