Home > Maintenance & Mods (L322) > 4 Wheel Alignment
4 Wheel Alignment
Having renewed everything at the back end a few weeks ago, finally got round to having a four wheel computerised alignment done. Fortunate to have Micheldever Tyres more or less on my doorstep, so booked in for 0900 this morning.
"Julian" took the car off me ( I hate giving someone else the keys!) and started work.
Car driven into bay with pit, and "reflectors" fitted to all four wheels. The initial scan showed up significant tow out on the Front Right and Rear Left (as expected on this one as been getting outer tyre wear at rear). Car then seemed to adjust itself a little and the toe out at the front came within limits, but still a little toe out.
Looking at the tyres, the fronts, which were nearly new back in July 2008, and have done @ 40K, are just starting to show signs of wear on the inside, with @ 4mm difference to wear on the outside. Rear left has gone more or less bald, especially on the outer edge, rear right, some outer edge wear, but this seems to have evened up since the rear end refit.
So decided no adjustment needed to camber front or back but adjustment to all the toe on both axles. Saw that Julian had a nifty air gun vibration tool to loosen up the track rod end nuts, not that mine looked like they needed it! Also good to see that when working from a pit/ramp, and with the right tools, all the adjustable eccentric bolts are accessible without wheel removal
So here are the results:
FRONT
Toe
Front Left Initial: 0.18º Min -0.09º Max 0.09º Final: -0.01º
Front Right Initial: -0.66º Min -0.09º Max 0.09º Final: -0.01º
Camber
Front Left Initial: -0.38º Min -0.83º Max 0.17º Final: -0.66º
Front Right Initial: -0.86º Min -0.83º Max 0.17º Final: -0.63º
REAR
Toe
Rear Left Initial: -0.87º Min -0.07º Max 0.27º Final: 0.15º
Rear Right Initial: -0.07º Min -0.07º Max 0.27º Final: 0.15º
Camber
Rear Left Initial: -0.78º Min -1.50º Max -0.50º Final: -1.22º
Rear Right Initial: -1.19º Min -1.50º Max -0.50º Final: -0.96º
See that simply adjusting the toe has brought the camber into line as well Thumbs Up
On test drive the car is very susceptible to road camber so pulls slightly to the left on normal A/B roads, goes straight if I straddle the white line. Not tried on motorway, but if still pulls to the left might take it back for more adjustment. I put two nearly new tyres on the rear at the same time, so might let them bed in a bit. ( now 3rd set on rear with these wheels, given the fronts have lasted since ownership)
Of interest, Micheldever use Autodata as their reference book, giving slightly different numbers to the ones quoted in RAVE for steering geometry (we are only talking 0.01 of a degree !)
Wheel alignment check and toe in adjustments £60. All done inside 90 minutes (includes tyre swap @ £28 )
Found a nice article (OK, its for racing cars but the idea is the same), that explains castor, camber and toe:
http://www.ozebiz.com.au/racetech/theory/align.html
A quick dash through eBay shows that toe/tracking and camber tools can be had from @ £100 for DIY .
Post #193334 11th Jun 2013 11:18am
Could just be me, but getting 1.3 more mpg (from 26.6 to 27.9) since alignment .
Post #195214 19th Jun 2013 9:14pm
You should get more MPG when correctly adjusted... Thumbs Up
Post #195224 19th Jun 2013 10:28pm
Ragerover
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Zambezi Silver
mm i wonder if i get mine done will i get 27.9 MPG???? Whistle Growing old is compulsory Growing up is optional
Post #195347 20th Jun 2013 2:41pm
probably, with the wind behind you and going downhill, and changing your engine to a diesel might help ... Laughing ... - .- -.
Post #195349 20th Jun 2013 2:47pm
After another day it is up to 28.2 mpg - enjoying this Very Happy .
Post #195364 20th Jun 2013 4:02pm
Still returning over 28 mpg, although I do have the A/C off atm due to it not working Big Cry but enjoying the breeze Smile .
Post #199452 18th Jul 2013 8:49pm
fuelly says 25.9.. Whistle ... - .- -.
Post #199455 18th Jul 2013 8:58pm
Click the image in my sig and check latest mpg .
Post #201130 27th Jul 2013 1:45pm
RichTDV8
United Kingdom 2015 Range Rover Vogue SE TDV6 Corris Grey
good read. I swear by having mine done every 2 years at Harwoods as the off road work in the winter i am sure knocks it out slightly 3.0 VSE - 2015MY
Corris with Black, RSE, 22 turbines, privacy, deployables
Post #201299 28th Jul 2013 6:18pm
dalziel
2003 Range Rover SE Td6 Epsom Green
Anyone know a good place to get this done near Harrogate?
Post #201448 29th Jul 2013 10:42pm
RR2008HSE
Oh yeah! You diesel guys just rub it in! Big Cry The only way I'd ever get 25+ mpg would be to push it down a steep hill. Mr. Green
Post #201453 30th Jul 2013 12:36am
twhincup
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
hahahahahahaha like you ever get over 20mpg in a ffrr.....oh wait are you saying they really do? Big Cry 2007 3.0L Diesel VW Touareg SE
2003 4.4 LPG, Vogue, Silver
Post #201463 30th Jul 2013 8:02am
supershuttle
TDV8 26mpg all day long without trying, no fiddling with LPG hoses, visit to Tesco to fill up once per fortnight (diesels run on anything no need for Ultimate, Maximum, Superior top price fuel) and good performance on tap now I have had it remapped Very Happy
However the 4 wheel alignment sounds like something I should get done, anyone know anywhere in the North West? Geoff
Post #201466 30th Jul 2013 8:37am
frikkadel
South Africa
thanks for the alignment setting, i have saved them and will be getting my L322 done when i take delivery here in RSA this week.
thanks
Post #395312 10th Jul 2016 6:07am
